Knock sensor gone/Missing ? 4.99 fix RIGHT HERE
Old Jun 4, 2013 | 12:52 PM
doublezerohatch's Avatar
Default Knock sensor gone/Missing ? 4.99 fix RIGHT HERE
So I was pulling on my wire harness and snapped the plug off of my Knock Sensor .. . I was like Shizzle!!!! off to Honda I go . . . .figured maybe 30 or 40 bucks to get a new one !!!! 240 + 13% tax OMFG !!!!
So I hit up Google and found some directions to bypass the knock sensor . . .I was a little skeptical at first . . . but I went out to radio shack and bought a 4.99 Piezo buzzer . . . I mounted the thing to my fuel rail with tie straps as per directions . . . I Reset the ECU with my scan tool. . .
HOOOORAH !!! the knock sensor code went away.
So here's a picture of my 4.99 knock sensor fix.
I attached the positive lead to the knock sensor wire . . grounded the negative under the fuel rail bolt tie strapped it on . . .took 3.5 minutes
I have been for a good rip . . .drove to work and back . . still no engine code . .
Maybe a small tip would be to wrap it in a plastic bag . . not sure how its gonna hold up when I wash the motor
Old Jun 4, 2013 | 01:21 PM
sleepyaccord96's Avatar
Default Re: Knock sensor gone/Missing ? 4.99 fix RIGHT HERE
dude wtf....
are you serious
wow, thats creative more power to you.
Old Jun 4, 2013 | 01:27 PM
Sure am. Knock sensor Bypass RIGHT HERE !!!!!!! 1000% dead serious. Google "Honda Knock Sensor Bypass" . . . . came across it while searching for solutions to my Secondary O2 Heater Circuit problem . . . you should see what I found out about the IAT sensor for a cheap mod . . ..
Old Jun 4, 2013 | 01:28 PM
grumblemarc's Avatar
The Grumpiest
This is why Civic owners get a bad rap.
Old Jun 4, 2013 | 01:29 PM
Everyone here flames the **** out of you for not doing research . .. I did some . .. here's what I found and it works !!
Old Jun 4, 2013 | 01:35 PM
The Grumpiest
Who flamed for no research? I'm flaming for the rigged contraption secured with zip ties.
Old Jun 4, 2013 | 01:39 PM
m_shake's Avatar
Pick N pull wasn't option?
Old Jun 4, 2013 | 01:41 PM
The Grumpiest
You can redeem yourself by saying that this is a temporary fix.
Old Jun 4, 2013 | 01:51 PM
Of course its a temporary fix . .. couple weeks . . maybe more . .. I just dropped all kinds of money into the car. . . I made a dumb mistake and tugged the harness the wrong way... if I tell my wife that I was drunk fiddling with my car and broke a 240 dollar part and I need it so it runs right. . . she would blow a 120 amper in my face!!!
accidents happen . ..
if for some reason someone needs a knock sensor in a pinch, cant afford the time to get to pick and pull or cant afford OEM prices that week . . . . and so on . . .and so on . . .
Here's a trick that works
@grumpyassmarc
Do you think us Honda owners are king of the pile . . . . everyone into any car customizes **** or does what works in a pinch . . . anything to get out of an expensive repair sometimes. . .. its not giving anyone a bad rap. Its +1 to the working man with kids trying to keep the CEL off.....
Old Jun 4, 2013 | 01:56 PM
The Grumpiest
Logic. Does not. Align.
Cars is an expensive hobby. Now the priorities come into consideration but not before when you were dropping money into it? I'm looking on Ebay right now and OEM replacements don't go for nearly that much money. I'm going to predict that that will be there next year except with a Ziplock bag over it.
The old addage "Do it right. Do it once" comes to mind here.
Old Jun 4, 2013 | 02:23 PM
This is a hobby when I have some spare time and money. Most days this is what I use to put food on the table.
Your prediction may be spot on, now this falls under a new category. . . "if it aint broke don't fix it"
simply I made a mistake after my swap and needed to fix this asap and with pocket change not the bank card . . . and I did.
And Im sure this will help someone somewhere, some way, somehow
Old Jun 4, 2013 | 02:25 PM
The Grumpiest
But it was broke and you didn't fix it.
Old Jun 4, 2013 | 03:20 PM
EsotericImage's Avatar
Retired Moderator
Alrighty..
SuperBowser707
Dec 4, 2012 07:49 AM
97blacklude
Jan 31, 2009 09:56 AM
crxb16ftw
May 20, 2007 10:31 PM
EF_LSVtec
Apr 10, 2003 11:25 AM
