obd1 pinout shocktower
By any chance does anyone have the obd1 pinouts for the 3 shock tower ecu harness plugs on the passenger side? I've been searching for awhile and only seem to stumble on the ecu pinouts.
my ecu was stolen out of my car along with the plugs so a bunch of loose wires where the ecu used to be. i used a multimeter to perform a continuity test for each wire that led to the engine bay, this is what i came up with using a ecu harness i took out of a automatic civic(eg) ex:
Plug 1=14 pin (from left to right)
top row: A16=alternator control(white/yellow) A6-=primary o2 sensor heater control(orange/black) A4=vtec solenoid(orange/white)
2nd row: D21=sensor ground 1(green/blue) D17=MAP sensor(pink/white) D19=sensor voltage for MAP D6=vtec pressure switch(orange/blue)
3rd row: D11=throttle position sensor(pink/black) D22=sensor ground 2(green/white) D20=sensor voltage for TPS(yellow/white) A21=ignition control module(red/green)
bottom row: D15=intake air temp(red/yellow) D13=engine coolant temp sensor(red/white) D9=alternator FR charge signal(pink)
Plug 2-10pin
top row: B2=logic ground 2(brown/black) D14=primary heated o2(white) A26=logic ground 1(black/red)
middle row: B11=CYP sensor p-side(orange) B12=CYP ground m-side(white) B13=TDC ground p-side(orange/blue) B14=TDC ground m-side(white/blue)
bottom row: B15=CKP P ground(blue/greemn) B16=CKP M ground(blue/yellow) empty
Plug 3-4pin
Top: A3=injector 2(red) A1=injector 1(brown)
bottom: A2=injector 4(yellow) A5=injector 3(light blue)
sorry for the shitty pics
Plug 2-10pin
Plug 3-4pin
i used this write up as a reference, although not all the colors matched
http://technet.ff-squad.com/wiring.obd1.htm
