Oil in spark plugs, stripped bolts, etc.
Old Jun 3, 2013 | 02:38 PM
murrellington's Avatar
Icon2 Oil in spark plugs, stripped bolts, etc.
So there was a ton of oil in my spark plugs when i went to change them. So i decided i would follow this video and replace o-rings and other parts so to stop oil leakage:
I had a problem with 2 of the bolts being stripped and i could not get them off. I ended up buying one of the bolt off kits to get them off, but now i have stripped bolts so i need new ones. Can i buy replacements at o'reillys or autozone something like that? One of the 10mm bolts was stripped so i need a new one. And one of the 12mm bolts that are longer. at 7:51 in the video he says "don't forget about these guys. I wasn't able to get those 2 off because i don't have any deep well sockets. I will buy some, however one of those long 12mm bolts is stripped too. Where can i get replacements for these bolts, and what exactly are they called? I'm new to this so i don't know much about cars.
Old Jun 3, 2013 | 09:08 PM
Meraut's Avatar
Default Re: Oil in spark plugs, stripped bolts, etc.
If you head down to your local honda dealership, the parts guys in the boutique are usually knowledgeable enough to track down the part numbers of the bolts with you. Just let them know that theyre the rocker arm bolts or w/e and they have all the diagrams available to see. Shouldn't be much of an issue.
Old Jun 3, 2013 | 10:54 PM
holmesnmanny's Avatar
Your best bet is probably the junkyard.
Old Jun 4, 2013 | 04:37 PM
Problem solved, car is back up and running. Thanks all for the suggestions.
jayupark
Dec 3, 2013 06:07 PM
YeaItsHim
Honda S2000
Jul 8, 2010 04:19 PM
McLude2nR
Oct 27, 2006 08:47 AM
Toda Built
Aug 1, 2004 01:47 AM
UncleBen'sRacing
Feb 16, 2003 01:17 PM
