need answers asap
Old Jun 3, 2013 | 02:28 PM
willfly's Avatar
Default need answers asap
Ok just realized my h22a is jdm not usdm I have a rebuilt usdm head for it will it work on a jdm block also will the head gasket work also...need to know before I go any further with this project! !!!!!!!
Old Jun 3, 2013 | 02:31 PM
Sparksman's Avatar
Default Re: need answers asap
The head should work just fine, what year is your h22? reguardless of jdm or usdm if it 97+ they are all open deck. Only 96 and down obd1 H22's were closed deck. Just make sure to get approprait head gasket for your block.
Old Jun 3, 2013 | 03:42 PM
willfly's Avatar
Mine is 99h22a what u mean by appropriate head gasket I have a oem gasket for h22usdm
Old Jun 3, 2013 | 04:07 PM
preludeNApower's Avatar
Needs to be a headgasket for open deck... 97+
Old Jun 3, 2013 | 04:45 PM
98vtec's Avatar
moderator emeritus
usdm or jdm doesnt make a difference. the year does.
92-96 blocks (p13 stamped) will be closed deck and require a headgasket made for a closed deck block.
97+ have open decks and require the appropriate gasket.
the head does not matter as they are all the same mating surface.
Old Jun 4, 2013 | 05:12 AM
willfly's Avatar
All parts are for 99
Old Jun 4, 2013 | 06:35 AM
98vtec's Avatar
moderator emeritus
So you have a 99 block?
Can you please be more clear?
Saying the parts are for a 99 doesn't tell us anything.
Old Jun 4, 2013 | 03:39 PM
1funryd's Avatar
Yeah quit talking text talk and be clear and concise about what you are asking because even I am confuse about what you are saying???
Old Jun 5, 2013 | 04:27 AM
willfly's Avatar
Some dudes on really **** me off I ain't no young kid I have a complete 99 jdm h22a and I have a new usdm h22 head that I want to make sure will work
Old Jun 5, 2013 | 04:33 AM
grumblemarc's Avatar
The Grumpiest
Sure.
Old Jun 5, 2013 | 04:53 AM
willfly's Avatar
Thanks for the info man!
Old Jun 6, 2013 | 12:30 AM
1funryd's Avatar
So then this was not clear enough for you???
If that was not clear then I do not know what you were asking...:-/
Type clearly and communicate your message better and you will get better results, if not then you bring the drama onto yourself.
willfly
Aug 9, 2013 09:47 AM
1fastlude1
Nov 15, 2008 02:22 PM
h22sedan
Aug 21, 2007 09:40 PM
dominate9
Sep 14, 2003 11:21 AM
dominate9
Aug 26, 2003 03:17 AM
