Why is my left side higher than right side
My EF is sitting lower on my driver side maybe about half a inch. I check my coilovers and they are equal on both sides... Could my shocks be causing it?
My EM1 is the same. Lower on the driver side. Had to adjust my coilovers for it to have the same ride height. Didn't have time to figure out what causes it to do that. There was a discussion about this a long time ago.
Okay. maybe you don't get the concept behind the adjustable part of adjustable coilovers. If you need any corner a certain height, you adjust that sleeve's height until you're satisfied. The goal is NOT to get the coilovers sitting at the same height. if that was the case you could use plain old lowering springs.
degraded shocks - and/or less spring rigidity. (not flaming)most likely caused be having a 150++ occupant and often no passenger.
going over bumps with unbalanced weight/getting in and out of vehicle - really does a number on suspension components.
Thanks dude I'll check my shocks I think that might have something to do with it... As fare as adjusting the coilovers I wanna go lower that's were my problem is cause I have adjusted them but it makes my ride higher like I said first time I ever have this problem I might just switch to Lowering spring
what's in the car will effect ride height as well. drivers side can be heavier than passenger. should really get the car corner balanced
its NORMAL.
cars sag on the driver side over time.
its normal.
adjust your coilovers to compensate.
its normal.
nothing to do with the shock.
its normal.
its normal.
