Why is my left side higher than right side
My EF is sitting lower on my driver side maybe about half a inch. I check my coilovers and they are equal on both sides... Could my shocks be causing it?
Re: Why is my left side higher than right side
Oh, phew! This *IS* about a car. ;)
Lol
Coilovers? So adjust them until all sides sit the same. Maybe this is a trick question?
They are all adjusted to the same height
Originally Posted by 19josh91
(Post 48833519)
(Post 48833770)
IM sure I know what I mean I've always used coilovers for all my cars and never had this problem so that's why I was asking
So I don't get what the problem is? Adjust them so everything sits even. Two people have told you the same thing already.
degraded shocks - and/or less spring rigidity. (not flaming)most likely caused be having a 150++ occupant and often no passenger.
going over bumps with unbalanced weight/getting in and out of vehicle - really does a number on suspension components. |
Thanks dude I'll check my shocks I think that might have something to do with it... As fare as adjusting the coilovers I wanna go lower that's were my problem is cause I have adjusted them but it makes my ride higher like I said first time I ever have this problem I might just switch to Lowering spring
Thanks for the help
what's in the car will effect ride height as well. drivers side can be heavier than passenger. should really get the car corner balanced
its NORMAL.
cars sag on the driver side over time. its normal. adjust your coilovers to compensate. its normal. nothing to do with the shock. |
Ok thanks for the help :)
