cps cel
Old Jun 1, 2013 | 10:50 AM
bpoweredeg6's Avatar
Default cps cel
put my fully built b series in my eg hatch and used a stock p30 to start it. it was throwing code 4 (crank position sensor). I then swapped the p30 for a p28 and the code went away. I noticed my intake cam was off alittle so I adjusted it and now its throwing the code again.does this mean my dizzy is bad? I had it in my b16 coupe with no problems.
Old Jun 1, 2013 | 01:43 PM
Default Re: cps cel
No one?
Old Jun 2, 2013 | 09:53 AM
Default Re: cps cel
bump. nobody had a crank position sensor code before? I need help
Old Jun 2, 2013 | 12:43 PM
nub's Avatar
nub
Default Re: cps cel
Since you didn't say I'll assume you have an OBD1 distributor.
Disconnect the engine harness to dizzy plugs. On the dizzy plug test for resistance between the blu/grn and blu/yel wires. You should have 350-700 ohms.
Test for continuity to chassis ground on the same two wires. It should read as open or no continuity.
bpoweredeg6
Jun 8, 2013 04:21 PM
PEK*EGGEM
Oct 20, 2009 09:38 PM
edm_ef8
Jun 21, 2009 11:42 AM
Daily Interlude
Jan 24, 2005 07:56 PM
