81 Prelude Fuel Relay Issue
Old Jun 1, 2013 | 06:08 AM
djkube's Avatar
Icon2 81 Prelude Fuel Relay Issue
My fuel pump relay seemed to have quit so I replaced it with a new one and my fuel pump still does not work when the ignition is turned on. I can bypass the relay with a jumper wire and the fuel pump works fine. I have power to the relay from the coil and the ignition but I can't get the relay to activate the pump. Any ideas on what to check?
Old Jun 1, 2013 | 08:07 PM
BlackCatt's Avatar
Default Re: 81 Prelude Fuel Relay Issue
All i can think of is to double check your wiring and ensure you have the
correct relay. GL with it.
Old Jun 2, 2013 | 05:23 AM
djkube's Avatar
Relay is correct. Will work on rechecking the wiring.
Thanks.
slowEGles
May 13, 2013 06:16 PM
3easy21
Jun 11, 2012 07:27 PM
2ndthtsurplace
Apr 10, 2011 11:15 AM
Domnificent
Jul 11, 2010 10:29 AM
JaHnAbOi
Oct 4, 2004 10:39 PM
