2002 accord wheel stud replacment
All you have to do is to unpress the wheel hub from the spindle. After that you can get it unpressed from you by an expert mechanic and than again press it to the original position..Yup..the work is done.
There is usually an indent behind the hub. Remove the caliper and rotor. Line up the stud to be removed with the void. Hammer out the stud. Slide in a new stud until it stops. You will have to make sure that you have a lug nut ready. Start tightening the lug nut, and the stud will start pulling into place. Tighten the lug nut with the rotor on, and it will pull into place. Be patient, and don't damage the stud's threads. This has worked well for me, and it generally is a quick job.
tell me how to replace the wheel studs on the front end of a Honda accord 2002
