Honda CR-V & Element 2WD & 4WD Element & CR-V
whats wrong with my alarm
Old May 31, 2013 | 09:24 AM
nachoman's Avatar
Default whats wrong with my alarm
Yahoo I finally got my CRV. It’s a 97... I’ll start a slow build thread with pics later.
My first hurdle is the factory alarm. I push the button on the fob and the doors unlock everything is fine. Once I open the door the lights start flashing like the alarm is going off. It probably is but my horn doesn’t work. I figure I’ll fix the alarm first. The other strange thing is she won’t start. I have to sit in her, turn alarm back on wait 30sec then turn it back off... then I have to quickly start her up.
Any ideas? Anyone hear of this before?
Old May 31, 2013 | 09:31 AM
dogbiscuit's Avatar
Default Re: whats wrong with my alarm
I've never seen a factory Honda act this way. are you sure you don't have a aftermarket system hooked up in there somewhere?
Old May 31, 2013 | 03:55 PM
nachoman's Avatar
You know what I think you’re right. The seller listed it as factory alarm, but the model number on the remote googled to be audiovox. After playing around I found that there seems to be a delay after I hit the button. If I open the door too soon the alarm goes off, if I wait 10 seconds it seems to work fine so I’ll see how that goes for a few weeks.
Thanx
Now to figure out the horn I think it’s burnt out because I can faintly hear a little noise when I try to honk it, so maybe I just need to replace the horn unit its self.
Old Jun 1, 2013 | 03:48 AM
Skillachie's Avatar
replace em with some hella super tones
Old Jun 1, 2013 | 11:53 AM
blackskunk2si's Avatar
yeah sounds like an aftermarket alarm with starter kill. if you deciede to remove it then you will have to reconnect the starter wire bac normal. the wire is cut and looped through the alarm.
and as far as the horns go, id replace them as well. if you hear something out of them, even faintly, then they are getting signal so the relays and fuses are good. i bought some horns off of ebay that were cheaper than hellas but look similar.
5G_Vtec
Dec 11, 2019 09:11 PM
smoked08
Audio / Security / Video
Apr 28, 2011 02:12 PM
2000siturboR
Feb 25, 2009 07:51 AM
8krdline
Sep 15, 2005 05:21 AM
aquarius
Jul 15, 2004 07:53 AM
