Fixing walbro 225 UGH!
Old May 30, 2013 | 06:09 PM
NZXTInerTia's Avatar
Default Fixing walbro 225 UGH!
So my dumb *** managed to just knock my ~500 miles new Walbro 225 fuel pump on the ground and I managed to break off the damn fitting and pin for the strainer. Is there any sort of way I can fix this? Potentially glue it back on? My tune is in five days and I DO NOT have time to buy a new one.. Anything that will hold up to fuel? Damnit..
Old May 31, 2013 | 07:39 AM
charliccs's Avatar
Default Re: Fixing walbro 225 UGH!
ouch...
share some pictures if you can...
Old May 31, 2013 | 12:17 PM
Well I have so far glued it with moderate to light amounts of loctite glue. Says its shock and liquid resistant.. We'll have to see if E85 agrees with it. I've used it before and it seems to be fairly tensile. Planning on using a good amount of oil when installing the fuel hose and standard screw type hose clamps when installing it on the hanger. If this doesn't work then I guess I'll have to fork out the 85$ for a new one.. Hopefully this will at least get me through my tune, I'm planning on letting it cure for the next couple of days. This sucks :/
NZXTInerTia
May 31, 2013 10:55 PM
noluckracing
Nov 8, 2009 05:45 AM
birds_sol_94
Aug 24, 2004 12:04 PM
T3T495GSR
Apr 20, 2003 02:07 PM
