NRG hub/quick release wiring issues due to age
Old May 30, 2013 | 05:15 PM
Dekorum's Avatar
Default NRG hub/quick release wiring issues due to age
I have a 92 Civic (EG), and after about 3 years of having a perfectly working horn, it stopped working. No, it is not the basic issue of getting the wire from the SRS connector to contact the back of the short hub. I am using an extra SRS connector with the ribbon stripped and the horn wire soldered in (so the connector remains OEM) and the other end with a soldered spade connector to go into the OEM shoe horn. I took apart my setup to see where the problem lied and I found it. I found one of the two wires from the short hub to the quick release cut, and I do not remember where it is supposed to come from. Can anyone help? These pictures will explain it better.
I just noticed that the picture is rather dark, but you can see the wire on the bottom is just cut apparently. Where is it supposed to go and where would I get a replacement wire?
While I am on the topic.. as I was disassembling the quick release, I removed the horn button to check if any of those wires were cut and I didn't really like the way I have the black wire attached to the gold 'clip' on the outer button. I just bent the spade connector and wrapped it around and then electrical taped it. Does anyone use a better technique that is more robust?
Old May 30, 2013 | 05:18 PM
n/a2boost's Avatar
Default Re: NRG hub/quick release wiring issues due to age
That wire should be going in the hole,at te 2'oclock position of your first pic.
It brings ground from the button(when pressed) to the shoehorn to relay causing the horn to sound.
Old May 30, 2013 | 05:36 PM
Dekorum's Avatar
I thought so... but now what do I do? How can I get behind this to get to the hole and how is the wire supposed to be attached back there? I think once I remove the hub nut the white piece with the gold foiled back come apart and I can get where the hole leads...
Also, do you have any advice for my second question? I want the black wire's spade connector to be attached to that clip on the horn button better so it is more robust and permanent.
Old May 31, 2013 | 08:07 PM
Dekorum's Avatar
Any suggestions on a robust way to keep that black wire's spade connector on the brass horn button ring/clip in the second picture?
Old Jun 3, 2013 | 09:13 AM
cvcrcr99's Avatar
You need to remove the hub and re-wire it. That simple. Mine getts pulled and rips after a few miles, I just leave it for now. I will fix the day before inspection if I haven't figured out a more permanent solution.
Old Jun 4, 2013 | 05:53 PM
Dekorum's Avatar
Yeah, I fixed it. So basically I removed the short hub and the white plastic thing wasn't even glued on like it should have been (must have dried up and lost its adhesiveness). I noticed that the black wire came out of its crimp to the ring connector that is soldered to the brass plate. Instead of getting a connector to crimp the wire into, I just stripped the wire and soldered it to the connector that was already soldered down. Then I proceeded to super glue the brass plate/ring to the white plastic (which is how it is supposed to be but for some reason neither of mine were glued), and then super glue the white plastic to the metal hub.
I am still looking for a good way to get that male spade connector (in the second picture in the OP) to the brass clip which holds the horn button into the wheel. I tried soldering a short wire to the clip and on the other end I crimped a female spade connector so its plug and play. Unfortunately I soldered the wire in a bad spot on the clip where now it cannot push all the way down and clip properly into the wheel.
TheMuffinMan
Mar 20, 2013 09:55 AM
kidari
Jan 12, 2013 06:38 PM
Uneekpinoysk8er
Jan 8, 2006 08:13 PM
JspecFerio
Nov 1, 2002 12:15 PM
