B16a2 hesitation
Old May 30, 2013 | 02:03 PM
kaison's Avatar
Default B16a2 hesitation
Beforehand, I recently replaced the camshaft plug and torque down everything as per http://www.lvracingscene.com/forum/s...al-replacement .
But now the car hesitates to accelerate whenever I push the throttle past 50% and it does not matter what gear I am in, as long as i push it past 50% the engine hesitates to accelerate and the exhaust makes the sound of an old classic car would make.
edit: I also notice that when the engine is hesitant, the check engine light would come on, but goes away when the I let off the gas.
Old May 31, 2013 | 04:53 AM
EsotericImage's Avatar
Retired Moderator
Default Re: B16a2 hesitation
when was the last time you did a tune up?
couldve damaged wires pulling them out.
could be not pushed on plugs all the way.
If it were me, Id do a full rotor,cap, wire and plug replacement
Old May 31, 2013 | 06:17 PM
kaison's Avatar
I replaced spark plug wires & plugs about 3-4 months ago. Today I ended up opening up the dizzy cap, to find out that the rotor was kind of loose. After tightening the bolt, I notice that the hesitation only happens when I am driving at ~2k-3k rpm, with no check engine light this time.
Thank you for responding
By the way, do you or someone know the exact torque specs for b16a2 cam cover? I know it says 16 ft-lbs for bolt #1-10, and 8 ft-lbs for bolt #11-14.
But when i compare the exhaust cam cover bolts (the cover that I took off) to intake cam cover (the cover that I never touched), the exhaust cam cover seems a lot easier to loosen the bolt, which lead to me believe that the torque must be higher than 16 ft-lbs.
Old Jun 1, 2013 | 12:44 AM
Ryank327's Avatar
I'm sure you figured this out but if not I would replace your cap and rotor. For the torque specs a bolt that has been at the torque longer is going to be seated better and harder to break at first then one that was just recently torqued into place.
Old Jun 1, 2013 | 12:14 PM
kaison's Avatar
Yes, I am in the process of replacing cap and rotor, but I was wondering if reinstalling cam shaft cover (wrong torque, etc) would cause sputtering in engine @ low rpm (2k - 3k rpm), or is it just coincidence that I was working on the car, and the dizzy cap and rotor fail.
Old Jun 1, 2013 | 01:00 PM
Ryank327's Avatar
It's just a coincidence especially consider you already opened the cap up and the rotor was loose,
Old Jun 2, 2013 | 11:44 AM
kaison's Avatar
Now I have pinpointed the exact problem, the spark plug in cylinder #4 (closest one to distributor) is half broken. Half of the plug is still stuck in the engine. New question, is it possible to take off the head without touching the valve spring etc (Just take off timing belt and certain bolts and remove the head?)
austinkli
23
Feb 7, 2008 12:57 PM
TyfinHX
Apr 28, 2007 01:57 PM
black cx
18
Nov 28, 2004 01:05 PM
TDRacing
Jul 18, 2002 10:58 AM
B18C-RnVA
Jul 16, 2002 07:36 PM
