D16Y7 3k RPM noise
Old May 29, 2013 | 09:04 AM
d16y7ohwell's Avatar
Default D16Y7 3k RPM noise
does it in neutral or in any gear
EDIT: noise is coming from the transmission
Old May 29, 2013 | 09:08 AM
grumblemarc's Avatar
The Grumpiest
Default Re: D16Y7 3k RPM noise
I have an idea. How about you stick your head under the hood and try to track this noise down and stop looking at a tach?
That noise could be anything. From your video it sounds like a vacuum leak.
Old May 29, 2013 | 09:12 AM
you're probably right about the vacuum leak. one of the valve cover bolts are broken and the bolt is just sitting in its hole (not tightened and not sealed)
but the noise sounds horrible, or is that just what the valve train sounds like? why does it come and go at 3k rpm only?
Old May 29, 2013 | 09:18 AM
The Grumpiest
Not gonna answer any more questions until you look under the hood.
Also wondering why we haven't bothered to fix known deficiencies?
Old May 29, 2013 | 09:20 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Loose heat shield maybe, List what mods are done to the car and especially if anything was done right before this started.
Old May 29, 2013 | 09:26 AM
just went out and looked at it, definitely coming from the transmission
the bolt is broken off in the cylinder head, that's why
Originally Posted by doctorake
Lose heat shield maybe
heat shield is already off
no mods and ive been hearing this for quite some time now while normal driving. when you drive down a road that has things on the sides that echo sounds you hear it more (under a bridge, bridge with concrete walls, etc)
Old May 29, 2013 | 09:30 AM
The Grumpiest
So that means you don't fix it?
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/noise-3k-rpm-only-when-car-driving-2918535/
Old May 29, 2013 | 09:37 AM
i don't have the tools to drill it out readily available. i will eventually
thank you for that thread. makes sense since december of 2011 i was being stupid drifting in the snow in a parking lot. lost control and rammed right front wheel sideways into a curb
hatchfreak92
Dec 2, 2004 08:27 PM
jeffb16
Oct 6, 2004 05:00 AM
Luserkid
Jul 21, 2003 05:07 PM
