D16Y7 3k RPM noise
does it in neutral or in any gear EDIT: noise is coming from the transmission |
Re: D16Y7 3k RPM noise
I have an idea. How about you stick your head under the hood and try to track this noise down and stop looking at a tach?
That noise could be anything. From your video it sounds like a vacuum leak. |
Originally Posted by grumblemarc
(Post 48823051)
That noise could be anything. From your video it sounds like a vacuum leak. but the noise sounds horrible, or is that just what the valve train sounds like? why does it come and go at 3k rpm only? |
Not gonna answer any more questions until you look under the hood.
Also wondering why we haven't bothered to fix known deficiencies? |
Loose heat shield maybe, List what mods are done to the car and especially if anything was done right before this started.
(Post 48823082)
(Post 48823082)
Originally Posted by doctorake
(Post 48823100)
Lose heat shield maybe
(Post 48823100)
Originally Posted by d16y7ohwell
(Post 48823146)
the bolt is broken off in the cylinder head, that's why
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/noise-3k-rpm-only-when-car-driving-2918535/ |
(Post 48823158)
So that means you don't fix it?
(Post 48823158)
