did search...no flames allowed. How much boost on a stock LS w/ T3/T4?
Old Oct 23, 2002 | 05:41 PM
TurbothisLS's Avatar
Default did search...no flames allowed. How much boost on a stock LS w/ T3/T4?
I have a stock LS with the turbonetics t3/t4.
how much boost can i run safely with walbro 255lph, dsm 450 injectors, AFC hack, itr exhaust w/ high flow cat?
will the block and car hold up under 9 psi of daily driven boost?
Old Oct 23, 2002 | 05:47 PM
Mase's Avatar
Default Re: did search...no flames allowed. How much boost on a stock LS w/ T3/T4? (TurbothisLS)
yes the block will hold that, but becareful of your ignition timing w/ that afc hack....
Default Re: did search...no flames allowed. How much boost on a stock LS w/ T3/T4? (Mase)
what do you mean? what do i need to watch out for?
Old Oct 23, 2002 | 05:55 PM
Mase's Avatar
you cant adjust your ignition timing w/ the afc hack, but w/ hondata and the EMS, you can
Old Oct 23, 2002 | 06:02 PM
rjardy's Avatar
Use msd BTM or a J&S ultra safeguard if you dont want (cant afford) a standalone.
Basically you need something to keep an eye on your timing.
Rob
Old Oct 23, 2002 | 06:27 PM
Default Re: did search...no flames allowed. How much boost on a stock LS w/ T3/T4? (rjardy)
so at 9 psi, i will need the extra timing adjustability?
also, running 7 psi, i don't have to worry about timing so much?
Old Oct 23, 2002 | 06:28 PM
Mase's Avatar
id retard your timing a couple degrees from stock
Old Oct 23, 2002 | 09:55 PM
with 7psi?
what do i need to do that?
ignition? msd 6al? or cam gears?
Old Oct 24, 2002 | 12:30 AM
IntegD's Avatar
New User
At 7psi, I would say set it back a few degrees on the actual distributor. But for 9 psi, I would say be safe and get the j & s or the msd btm so you can pull timing at higher levels of boost.
Old Oct 24, 2002 | 12:35 AM
pissedoffsol's Avatar
25 Year Member
Default Re: did search...no flames allowed. How much boost on a stock LS w/ T3/T4? (IntegD)
7 psi, 9 psi- its all bullshit. you need to tune based on how many cfm's your turbo is pushing IN to the motor.
DohcVtecCrx
May 16, 2004 06:40 PM
Tad
Dec 17, 2003 03:10 PM
spike
Jun 27, 2002 11:00 AM
kidkutz
Jun 25, 2002 01:34 PM
