p75 rechipped for vtec??
Old Oct 23, 2002 | 05:19 PM
chethewitt's Avatar
Default p75 rechipped for vtec??
just wondering if anyone knows how a p75 could be rechipped for vtec.
tonight i tried this in my car (as a test) and vtec engaged at 5000 rpm and redline was higher than 8500rpm.
it turns out some kid sent this ecu to a friend of mine to rechip it, as he's looking for a chipped p28, wanted a skunk2 program or something. well the ecu was throwing vtec codes which prompted us to put the ecu in my car.
i have a b16a...stock internals, couldn't really rev it any higher without damage...but i suspect redline is around 9000.
Old Oct 23, 2002 | 05:22 PM
Katman's Avatar
Default Re: p75 rechipped for vtec?? (chethewitt)
..as far as I've tested, no, the P75 ecu cannot be converted into a VTEC ecu. Even though a P75 uses the same motherboard as a P72/GSR ecu, that seems not to matter to the P75...its a stubborn biatch of an ecu in terms of converting it for vtec use.
Old Oct 23, 2002 | 05:34 PM
chethewitt's Avatar
Default Re: p75 rechipped for vtec?? (Katman)
this is what cory thompson and mike yonkey thought also, but the ecu has the p75 bar code and seems like it was from an obd1 ls/gs/rs integra.
Old Oct 23, 2002 | 05:41 PM
Katman's Avatar
umm, yeah, a P75 IS an OBD1 LS ecu, if you weren't sure.
If you didnt know, there's actually 2 versions of the OBD1 LS ecu, P75 & PR4. If you ever get a hold of a PR4 ecu with an 02D011F0-1500 motherboard, that one is totally capable of being converted to vtec.
I tried converting a P75 long ago.
I even had a P72 side by side with a P75; moved over the parts needed from the P72 over to the P75. What happens is VTEC kicks on for a quick second, then instantly goes into bitch-*** check engine light mode and jumps out of vtec. to P75 ecus. lol.
[Modified by Katman, 6:41 PM 10/23/2002]
[Modified by Katman, 6:42 PM 10/23/2002]
Old Oct 23, 2002 | 05:42 PM
chethewitt's Avatar
it throws a code 41.
and says s.tec on the sticker on the chip.
if this helps any???
Old Oct 23, 2002 | 05:47 PM
Katman's Avatar
41 = Heated 02 sensor code
You said VTEC works with this specific P75 you have?
Do me a favor, can you take the ecu cover off and tell me what the motherboard number is you see on it?
Here's a pic to help you locate this number:
Old Oct 23, 2002 | 05:51 PM
chethewitt's Avatar
hey whats up, i just left the garage like an hour ago and thats where the ecu is. cory might be going back later tonight so i'll have the code for you either tonight or tomorrow.
do you have aol IM by any chance?
if you do i'd like to ask you a few questions...my aim is "chethewitt"
thanks, chet.
Old Oct 23, 2002 | 05:55 PM
Katman's Avatar
I'll IM you using Honda-Techs' IM'ing system...
Old Oct 23, 2002 | 06:02 PM
chethewitt's Avatar
i'm not sure ht's messaging system is working...
Rooftop voter
Mar 21, 2007 06:13 AM
Addicted2Racing
10
Jan 27, 2004 04:29 PM
smkngsr
Dec 4, 2002 03:11 PM
nautica_t
Dec 4, 2002 01:09 PM
eg6ajk
Jan 31, 2002 11:58 AM
