Tachometer help
Old May 25, 2013 | 06:33 PM
DamnThatsRexy's Avatar
Default Tachometer help
Hi everyone I need some he
P with my tach
Basically, it jumps up and down and moves weird. When I'm accelerating it shows a little accurately but not very much. Wen I'm at same speed it will move up and down when it wants or do whatever, does anyone know ow to fix this? Thanks!
Old May 26, 2013 | 02:17 AM
skill178's Avatar
Default Re: Tachometer help
Sounds like somethin in the wires, check all the wires coming from the dizzy
Old May 26, 2013 | 02:30 AM
swordofdoom's Avatar
1.) Loose ign wiring
2.) check your cap and rotor
Old May 26, 2013 | 03:22 AM
Could you be a little more specific, I'm not really in the car scene, so I'm new to this.
Old May 26, 2013 | 03:58 AM
EFvtec Yo!'s Avatar
Take your Distributor Cap off and inspect all the wires and terminals on the ignitor. Ignitor will be the little silver sqare box mounted on the inside of the dizzy. Should have like 3 or 4 square wire connectors. I had the same issue before and my wires on the terminals of the ignitor were somewhat loose and not firmly attached.
Old May 26, 2013 | 06:29 AM
Son2BEHO's Avatar
Make sure the rotor is tight too I had a loose one cause problems
Old May 26, 2013 | 08:04 AM
Spug's Avatar
This.
Pretty sure most people solve this issue by simply replacing the distributor.
Old May 26, 2013 | 09:51 AM
If the wires Are in fact loose what can. Do about it if anythng
Old May 26, 2013 | 10:02 AM
KINGVEM^^ED6's Avatar
Check your grounds
averyvm
May 8, 2009 11:37 PM
mattymatt
Feb 23, 2004 04:57 AM
SenekaGSR
Dec 29, 2003 02:41 PM
Casey
Jul 28, 2003 02:15 PM
OutLuDeD
Mar 1, 2003 07:50 AM
