newbi in need!!!! h22 swap, wont start.
hey guys, i just did a swap to my 4th gen prelude (1992) si model.... i have no idea why but i am not getting power to my fuel pump, or any power to my entire engine.... all the wires are connected, hoses in, but when i turn the ignition, the engine cranks but does not start.... i swapped out a f22b for a h22a which came from a japanese accord with a complete harness and the ecu.
so again.... all wires, hoses ect. are hooked up.... just no gas being sent to engine and no power in the engine= no start :/
thanks a million guys, in advanced.
So no spark and no fuel?
What did you do to your swap wiring wise was it do it yourself wiring or was it an aftermarket harness?
Are you positive you are getting no spark or fuel, or are you assuming because it wont start? Can you hear the puel pump prime when you turn the key to the "ON" position? Is your fuel rail being primed with fuel? Could be a blown fuel pump fuse. Did you use a spark tester to make sure you're getting spark as well?
Double and triple check everything. When I did my swap it took me 3-4 complete head to toe checks of the car to find the tiniest little things that kept it from running. Keep at it, you'll find it.
attia
Oct 30, 2014 04:41 AM
