itr...Koni and ground control help
Old May 24, 2013 | 07:55 PM
SuperChargeEF9's Avatar
Default itr...Koni and ground control help
I just install koni shocks and ground control coils but for some odd reason the front is slam even when i raise the coils up...but the back work just find....any input would be great.
Old May 24, 2013 | 10:30 PM
KraZyCHOWMEIN's Avatar
Default Re: itr...Koni and ground control help
Are the springs reversed?
I had a shop do that to me with my GSR and it had the same symptoms. Front springs were installed in the rear and rear were in front.
Old May 24, 2013 | 10:39 PM
racebum's Avatar
what length are the springs? typically you use 8" in the front and 7s in the back.
if you bought some second hand set you need to know your rates and your lengths
Old May 24, 2013 | 10:42 PM
10cjennings's Avatar
which slot do you have the c-clip on the shock body in? It serves as the lower mounting point for the coilover sleeve. There are 3 slots, spaced like an inch apart (from memory) move the C-clip up to the top slot. You can do it with the shocks on the car, just slide the sleeve up out of the way with the wheels off the ground.
Old May 25, 2013 | 05:19 AM
Thanks guys im going to try everything you guys say. Im thinking i might have put the wrong spring
slowtegkauai
Suspension & Brakes
Sep 29, 2011 08:05 PM
lawlsss
Jan 17, 2009 01:34 AM
threesixes
Suspension & Brakes
Feb 5, 2007 10:13 AM
ccjb100
12
Nov 19, 2002 05:53 AM
tr4il
Nov 20, 2001 04:09 PM
