Thoughts on Exedy OE clutch for S1 trans?
Old May 24, 2013 | 06:18 PM
xotic_crx's Avatar
Default Thoughts on Exedy OE clutch for S1 trans?
Just wondering the thoughts on this clutch for a mild GSR build. I've used this clutch with a Fidanza flywheel on my SOHC in my autox car with great results, and in a friend's JRSC'd D15B without issue as well. Motor should see about 180whp when all is said and done (PR3's, bolt-ons, and eventually ITR/mild cams). The car's an autox car so it won't see slicked out drag launches, although my R comps are fairly sticky lol. Going to use the Fidanza flywheel as well.
This one below fits my budget and like I said, had good experiences on my similarly modded SOHC. I'd rather run an OE Exedy vs an eBay heavy clutch.
http://www.ebay.com/itm/EXEDY-CLUTCH-KIT-FIDANZA-FLYWHEEL-90-91-INTEGRA-RS-LS-GS-1-8L-B18-S1-Y1-B16A-/161026908504?pt=Motors_Car_Truck_Parts_Accessories&hash=item257df3a158&vxp=mtr
Old May 24, 2013 | 06:33 PM
90_EX_Civic's Avatar
Default Re: Thoughts on Exedy OE clutch for S1 trans?
why not get a stage 1 exedy?
Old May 24, 2013 | 07:01 PM
xotic_crx's Avatar
Two reasons: 1 is I have had good luck with the same setup on my D, as has my aforementioned friend who's putting down more power than me; 2 is I am already well over budget for this build and I don't wanna push my luck with the missus going further over lol
Old May 24, 2013 | 07:12 PM
just re read it. they fly wheel would bring you over. stage 1 clutch kits are about 250.
Old May 24, 2013 | 07:27 PM
xotic_crx's Avatar
I need a flywheel as well, one that came with the trans would need a resurface at least, and it's stock. I really like the way the 7lb feels on my setup too.
Old May 25, 2013 | 02:59 PM
F22Master's Avatar
I have a stage 1 organic (P/N 08804) and its great! Just about done breaking it in, and its soooo smooth. Im running a resurfaced stock flywheel. Its on a stock motor B16 (just I/H/E). Launches damn good, very easy to feel the tires' grip level. Then, it grabs like crazy when you dump the clutch during shifts. Also has a decently mild pedal pressure. I got mine for $252 shipped from lightning motorsports. It's supposed to be able to take up to 200 ft/lb of torque, so probably around 300hp on a B16. I would highly suggest getting the stage 1!
Iloveyourhonda92
Jun 29, 2012 07:10 AM
Cynical 1
Sep 22, 2010 05:37 AM
OrangeTeggy
Aug 18, 2009 08:30 PM
aleks77
May 18, 2007 09:16 AM
redDAinteg
May 2, 2005 02:40 PM
