Car won't start but radio, dash lights work?
Old May 23, 2013 | 08:20 PM
BTe's Avatar
BTe
Default Car won't start but radio, dash lights work?
2000 civic se
Had it parked the whole winter.
I can jump the car and drive it around, run it for half an hour or so, but when I turn it off and try to start again, all I hear is a humming sound when I turn the ignition.
The radio and lights work, I even cleaned the posts and terminals?
Bad battery?
Old May 23, 2013 | 08:35 PM
peteyparado's Avatar
Default Re: Car won't start but radio, dash lights work?
most times have the battery tested..
Old May 24, 2013 | 12:58 PM
fiveOHthreePDX's Avatar
Sounds like it could possibly even be the alternator. I am no mechanic though but it's just what comes to mind if I were dealing with the same situation. Maybe get that looked at as well? Good luck
Old May 24, 2013 | 01:09 PM
CivicInUse22's Avatar
get a multimeter and check the battery voltage. should be in the 12.x range. Then start the car and take the reading on the battery. should be between 13.4 - 14.5v. if not your alternator is bad or slipping. check the belt tension
Old May 24, 2013 | 02:16 PM
kalypsofusky's Avatar
Had the same problem with my car, it was bad terminal connections. Check your grounds and see if you can get it to start, before spending money on the battery.
Old May 25, 2013 | 03:39 AM
jonsey1886's Avatar
10 Year Member
How far are you from an Advance Auto Parts, NAPA, AutoZone, etc?
Most times those places will test your battery, alternator, and starting system for FREE without you having to remove anything just drive the car up and ask for a check. Just um make sure you don't buy any replacement starters or alternators from them. Unless you want them to die within 12 months....... Consult this thread for replacement recommendations:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-your-guide-buying-quality-aftermarket-maintenance-parts-your-civic-3114911/
Also should you buy a battery from them stay away from the Bronze or Economy aka "El Cheapo" level batteries.
chloe_m
Honda Civic (2001 - 2005)
Oct 30, 2017 04:54 PM
ej1_lou
Audio / Security / Video
Feb 4, 2015 08:20 AM
sydag5
Jul 2, 2006 12:13 AM
Lo-Buck EF
Aug 24, 2002 04:38 PM
Lo-Buck EF
Aug 23, 2002 10:35 PM
