Car wont budge.
Old May 23, 2013 | 05:44 PM
cola81188's Avatar
Icon2 Car wont budge.
I have installed my engine after rebuild. the transmission is installed. THe thing is my battery died and I need to push it out of my garage to jumpstart it but i cannot move it. It seems like the front wheels wont move. When i lifted the car up, I manually rotated the front wheels and the opposite wheel would always spin the other direction. Any thoughts are greatly appreciated.
Old May 23, 2013 | 06:55 PM
Lizardslap's Avatar
Default Re: Car wont budge.
you may have not alined the clutch properly when you put it back in I did that when I put the motor in my car and was very not pleased about it at least you dont have to pull the motor again to get it out
that or its in gear or push harder lol
Old May 23, 2013 | 06:57 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
take off the brake?
Old May 23, 2013 | 07:29 PM
CivicInUse22's Avatar
did you try putting it in neutral?
Old May 24, 2013 | 08:45 AM
Chris Westlund's Avatar
OP Didn't specify whether it's a manual or an automatic transmission. I'm assuming it's a manual. If this is true, Make sure you installed the pin on the shift linkage correctly and that its tight. The shifter may seem like it's in neutral, but if that pin isn't in all the way it might not be pulling the tranny completely out of gear. Easy to tell if you're under the car.
Old May 24, 2013 | 01:30 PM
OP doesn't understand why one wheel turns opposite of the other lol, linkage pin is far beyond his understanding
DLS2000Accord
Jun 26, 2017 09:38 AM
Si_eg6
18
Jan 22, 2009 06:04 PM
spooncivic1
Jan 8, 2006 07:14 PM
LostAndFound
Jul 19, 2005 10:34 AM
torr
May 29, 2005 08:47 PM
