What's the worst thing that could happen?
Old May 23, 2013 | 04:24 PM
DingDang's Avatar
Default What's the worst thing that could happen?
So the fuse to my heat motor relay keeps blowing. So I'm thinking about putting a 10a fuse in instead of the regular 7.5a again... What's the worst thing? Curious...
Old May 23, 2013 | 05:01 PM
Nbboy7's Avatar
Default Re: What's the worst thing that could happen?
Wires will melt. You may have a short some where fix it and run the appropriate size fuse.
Old May 23, 2013 | 05:32 PM
DingDang's Avatar
I see. What are the chances of the wires melting? 100%?
Old May 23, 2013 | 05:37 PM
HondaPartsHero's Avatar
Technical Hero
Old May 23, 2013 | 05:46 PM
doood's Avatar
been there done that
enough that you probably shouldnt go dicking around with it
these fuses are the amps they are for a reason
Old May 23, 2013 | 05:50 PM
grumblemarc's Avatar
The Grumpiest
Try it.
Gunmetal_B20_Hatch's Avatar
post pics of the ashes.
Old May 23, 2013 | 06:22 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
baby jesus will cry.
Old May 23, 2013 | 06:52 PM
fcm's Avatar
fcm
Old Fart
What they all said.
I have a 64 Mustang in the shop right now, with a $1000 wiring repair bill, because the owner installed a "bigger fuse".
If the fuse is blowing, it means the blower motor is burning out, it does not get better, it only gets worse, the load gets "bigger" and eventually becomes a dead short.
It is actually better to have an instant dead short then one that builds, [more time for wiring to heat up] and when you install a bigger fuse, it can handel an even bigger load, more heat, then all of the sudden, PUFF, the wire insulation is hot enough to burn, if your real lucky, only that one lead is damaged, circuit broken before other wiring shorted, re:
94
Old May 23, 2013 | 06:59 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
it must be the full moon
Old May 24, 2013 | 03:13 AM
The Grumpiest
You know he's going to run the bigger fuse anyway.
Old May 24, 2013 | 08:05 AM
datbumper's Avatar
in4fyrepics
Sic_DA_Nine
Jan 8, 2007 09:54 AM
tuan...
Aug 7, 2004 05:47 AM
