i have some questions about my EJ6
Old May 23, 2013 | 06:40 AM
d16y7ohwell's Avatar
Default i have some questions about my EJ6
what is this little black rubber thing for?
is this a big deal (i accidentally dropped it ) car still runs seemingly fine
how am i supposed to remove the throttle position sensor?
what is this for? it was bolted to the fuel rail
one last thing, were my fuel injectors dirty enough?
Old May 23, 2013 | 06:45 AM
grumblemarc's Avatar
The Grumpiest
Default Re: i have some questions about my EJ6
Buy or find a download for a field service manual.
Old May 23, 2013 | 07:38 AM
sleepyaccord96's Avatar
4th pic from the bottom is your fpr fuel pressure regulator.
to remove the tps you must use a cut off wheel or a dremel and cut a slot in it to where you can use a flat head screw driver to unscrew the bolts...
Old May 23, 2013 | 07:40 AM
injectors do look like ***
Old May 23, 2013 | 08:34 AM
cvcrcr99's Avatar
You need to number the questions next time to make answering easier.
-Cover for what looks to be an idle adjust screw.
-Looks fine I guess.
-Search next time. Cut slots in it and remove with a screwdriver. If you do not know what you are doing, don't touch it. It usually needs to be calibrated once removed.
-Fuel pressure regulator
-Yes
96ek
13
Sep 2, 2013 10:35 PM
khkchan
Jun 22, 2005 06:45 PM
Full-Race Geoff
Apr 12, 2002 05:00 PM
yellowbuffalo
Jan 3, 2002 03:54 PM
Lei Siew Long
Aug 17, 2001 01:37 PM
