i have some questions about my EJ6
what is this little black rubber thing for?
is this a big deal (i accidentally dropped it ) car still runs seemingly fine
how am i supposed to remove the throttle position sensor?
what is this for? it was bolted to the fuel rail
one last thing, were my fuel injectors dirty enough?
Re: i have some questions about my EJ6
4th pic from the bottom is your fpr fuel pressure regulator.
to remove the tps you must use a cut off wheel or a dremel and cut a slot in it to where you can use a flat head screw driver to unscrew the bolts...
You need to number the questions next time to make answering easier.
-Cover for what looks to be an idle adjust screw.
-Looks fine I guess.
-Search next time. Cut slots in it and remove with a screwdriver. If you do not know what you are doing, don't touch it. It usually needs to be calibrated once removed.
-Fuel pressure regulator
-Yes
-Yes
khkchan
06-22-2005 06:45 PM
