Cutting lca bolts with rotary tool.
Old May 22, 2013 | 02:07 PM
chillerice's Avatar
Default Cutting lca bolts with rotary tool.
Hey guys,
This might be in the wrong section but it's as close to a cutting topic as I could get.
I have a Craftsman rotary tool. Single speed 28,000 rpms. The welded nut on my LCA to trailing arm is frozen with the bolt. I already got it half cut with my sawzall. My rotary tool seems to have collets that are 1/8 " which I think the Dremel mandrel shank is too.
Question is. I saw Dremel brand have a EZ lock mandrel/metal cut off wheels that cut bolts easy from Sears. Can other brands mandrels/cut off wheels be used with other brand tools?
Old May 22, 2013 | 09:50 PM
turbohatch96y7's Avatar
Default Re: Cutting lca bolts with rotary tool.
Just hit homedepot and get yourself a 110v grinder
DEWALT DWE4011 4-1/2-Inch Small Angle Grinder with One-Touch Guard - Amazon.com DEWALT DWE4011 4-1/2-Inch Small Angle Grinder with One-Touch Guard - Amazon.com
Cheap and durable and you can use it for lots of other things. the wheels are cheaper than those tiny dremel wheels.
What you invest is what you gain!!!
Old May 23, 2013 | 04:48 AM
chillerice's Avatar
Originally Posted by turbohatch96y7
Just hit homedepot and get yourself a 110v grinder DEWALT DWE4011 4-1/2-Inch Small Angle Grinder with One-Touch Guard - Amazon.com
I have one of those and tried it. Won't fit in the space bro. The nut is the one next to the wheel facing the front of the car. It's a very tight space.
Old May 23, 2013 | 06:56 AM
g.r.crx's Avatar
Originally Posted by chillerice
Hey guys,
yes it will work. you need http://www.acehardware.com/product/i...LAID=109397927
it'll work takes forever and you will go through a couple of blades.
Old May 24, 2013 | 05:29 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
Make sure you get the fiberglass reinforced ones, the regular ones they have will break verrry quickly. And yea, you'll go through a couple.
q071302
Honda S2000
Jul 4, 2017 01:20 AM
cehcivic15
14
Jun 18, 2012 12:50 PM
siblues
Dec 29, 2006 04:48 PM
Timberland237
Suspension & Brakes
Nov 9, 2006 11:29 AM
MI4$DC5
19
Apr 2, 2005 09:10 AM
