700ish goal. Fuel questions
Ive got a CNC Werx CSS, low cr ITR. Im shooting for 700ish, 680-750. Heres the fuel setup:
Bosch 1600cc injectors
Walboro 400lph in tank
6an lines to a Bosch 044, then 6an to the rail.
Should I run c16 or e85?
Damn. So I should run dual 044s, with a 400 in tank on c16. Ive made my mind up as I was making this post. Ill be sticking to c16. Looks like Ill be maxing out my injectors. Ive got an Aeromotive external FPR as well.
im making 779 on an aeromotive pro pump with id2000's and e85 man
you can always bump the fuel pressure up as well
i made 650 on rc1000's and an aeromotive a1000 with e85 for fuel
Do you already have the walbro 400? If not then do dual Walbro 255's in parallel. 710whp on E98 with room left to go. Cheapest option you can have if doing 2 fuel pumps....
Will it really? Again I have very little knowledge on fuel, So just run a 400 in take and c16 and I would have no problem going a bit over 600? Also Ive got a -6 ss line with inline fuel filter, Is it worth running that to the fuel rial?
Walbro 400 q16 1000cc injectors on many cars have gone 600-625 if not higher. The 1600's will get you further than your goal with that pump
If it means anything i made 660whp on E85 with an Inline 255walbro and an Intank 255 on all stock lines/FPR/fuel rail back in the day. Pretty sure the same setup can make about 740whp on Racegas.
Ive made 721 on PTE1600's, an aeromotive A1000, -8an line on E85. Car ran and drove around just like a bone stock car and idled smooth at 950RPM. If you want the car to drive and idle like stock, you going to need to speed the injectors up. Thats why i originally chose E85 on those 1600's.
Who is Mr Robot?
When getting into injectors this big if you want low/mid rpm driveability then you need to look into an 8 injector staged setup... have smaller primaries for low load/low rpm driving and then have the larger secondary set come online when you hit a certain load/rpm point
That way the car will idle and cruise smooth as butter but haul *** when the need arises
I am not to concerned with driveability wantboost. I ended up finalizing the setup on the following:
bosch 1200s
dual o44s
sumped tank with -8an feed
factory feed revamped into the return
q16
Im going to do a duel map tune and switch from 93 to Q for when I want to run high boost. Im looking at 500whp on pump and 700 on Q.
bosch 1200s
dual o44s
q16
Sorry big thumbs and typing on a cell phone. a1320honda mentioned the aeromotive a1000. I was wondering if there were any issues driving on the street.
