Mini Me Swap went great, runs bad....
Old May 21, 2013 | 01:35 PM
doublezerohatch's Avatar
Default Mini Me Swap went great, runs bad....
So I have a 2000 DX hatch. I gathered the parts from a 99 acura EL 1.6. I used the engine harness, the intake, the head and the Acura P2E ecu. I used my stock d16y7 exhaust manifold and all new gaskets.
my timing is set correctly, triple checked.
Currently the car runs just ok . . . its very glitchy and jumpy under 3500 rpm . . . almost like the computer is constantly adjusting something. . . its driveable but seems to have no power under 3500. it seems to be great from 3500 rpm onwards pulls hard vtec engages . . revs right up to 7200-7300 rpm . . .
Here are the problems I encountered.
I couldn't use the stock acura d16y8 header because it only had 1 o2 sensor plug in and the ecu wants a secondary. . . so I used my stock built in cat exhaust. I extended the wires on the acura harness to reach the front of the motor and the primary o2.
I ran 4 wires directly to the ecu and hooked up the secondary o2 sensor.
the ecu asked for a knock sensor . . . I installed one.
another thing I noticed that my old civic would always rev when cold and stay reved up . . . with this setup the engine only revs until you tap the gas and drops to 650rpm . ..
650 rpm . . . .idles really nice and smooth . . . but really ? is that what its supposed to rev at?
this is my situation. if anyone can shed some light or has some experience please let me know.
is there a difference in timing between the y7 and the y8?
Old May 21, 2013 | 01:47 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Mini Me Swap went great, runs bad....
Still trying to see where the "runs bad" part of this is.
Old May 21, 2013 | 02:23 PM
Marvin1985's Avatar
How do you have vtec with a p2e ecu? You should be using a p2p at least
Old May 21, 2013 | 02:30 PM
The Grumpiest
That thought crossed my mind as well. Is the Acura ECU somehow different since its Canadian?
I do have the P2P ecu from a 99 El. P2P I meant.
Its so jumpy and feels like its lagging. Driving in traffic is horrible. My old Y7 head with a blown headgasket had more power under 3500 rpm and was way smoother. I have driven an acura 1.6 el and the motor didn't feel like this either.
Whats the trick?? someone who has done this before is gonna know whats going on.
Old May 21, 2013 | 03:10 PM
I have the 99-2000 Y8 intake and Head. I have been reading and I have a bunch of cold start assist crap on my intake and head. Its different than the 96-98 head and intake. I capped them off like the tutorial I read said to. Im going to hook them all up and see if there is a difference.
PJHennessy203
Jan 19, 2016 05:10 PM
92siturbro
24
Mar 6, 2014 09:38 PM
Robunkus
Feb 16, 2012 12:00 PM
bigturbo
May 20, 2009 12:45 PM
boot machine 5000
Sep 5, 2002 06:08 PM
