h22a erl sleeves or darton sleeves
Old May 21, 2013 | 12:24 PM
sshh's Avatar
Default h22a erl sleeves or darton sleeves
i am checking on sleeving my h22a block,
i thought on fully sleeve and build it at ERL.
the secound option is draton sleeve it and will do the rest of the build.
which one you consider as the best option for H22A fully builld by erl or darton sleeve it?
thanks
Old May 21, 2013 | 12:29 PM
blade0314's Avatar
Default Re: h22a erl sleeves or darton sleeves
On my car im using a erl sleeved block and its the nations fastest street all motor h series.. Erl does a really nice job
Old May 21, 2013 | 12:40 PM
sshh's Avatar
sound good,
i am building it for turbo setup about 700hp.
Old May 21, 2013 | 01:12 PM
ESP.net's Avatar
Erl is probably cheaper Darton MIDs spendy on labor
Old May 21, 2013 | 01:55 PM
sshh's Avatar
Have your bar in my sol, the best bar in my country ,
so erl is adviced for 700hp+? or with darton
Old May 21, 2013 | 02:13 PM
intevic94's Avatar
erl i think us darton sleeve if i not mistaking
Old May 21, 2013 | 04:37 PM
92redhatch's Avatar
ERL uses darton. I ran an ERL sleeved block. I wouldn't use any other company for sleeving. They are more expensive then all of the other sleeving company's but you get what you pay for.
Old May 21, 2013 | 05:50 PM
zakura R's Avatar
Best sleeve golden eagle my 2 cents
Old May 22, 2013 | 03:10 AM
Runnerdown's Avatar
I had erl do an h22 for me and it was very well done. They have a very nice finish hone too. The leak down on the cylinders was the lowest I have ever had after a few hours dyno time. The only thing I didn't like is that it was a different block, not the one I had originally sent.
Old May 22, 2013 | 04:36 AM
sshh's Avatar
What do you mean by lowest cylinder leak?
After talking with Erl they are not using darton sleeves,
They are using their sleeves.
Therfore i am not sure to decide which will do the job.
Old May 22, 2013 | 04:48 AM
Muckman's Avatar
Moderator in Chief
ERL uses a block gaurd at the deck to support the sleeves?
Old May 22, 2013 | 09:39 AM
Runnerdown's Avatar
By leak I mean checking the cylinder individually with a leak down tester. After the normal dyno run to seat the rings the numbers I got were the lowest I had seen yet. I will typically see 5-7 percent depending on the ring gaps but this one was more like 2-3. I came to the conclusion that their finish hone contributed to this.
Old May 22, 2013 | 09:50 AM
Runnerdown's Avatar
Yes, on open deck motors. They call it a deck support. I think for serious power output this may be a nice thing but I have had sleeved blocks with and without and not noticed really any long or short term issues either way. I do like the idea of mimicking the open deck like Honda for streetcars though.
Erl's site has some good tech briefs on it that explain their sleeve process, deck supports, stress relief and line honing info.
What I do not understand is that several sleeve companies claim their sleeves are good for xx psi of boost. But really, shouldn't max cylinder pressure be the true measure?
Old May 22, 2013 | 10:44 AM
extralargenog's Avatar
GE > all. I had one loved it. Got a deal on a Benson/Darton so that's whats in it now, but next block I buy will be GE again
Old May 22, 2013 | 03:48 PM
92redhatch's Avatar
I always thought of GE as the cheap sleeve company. Until recently that there is cheaper sleeving company's. You will be fine with any option you chose. Even the guys making 1000+ aren't cracking sleeves.
Old May 23, 2013 | 09:15 AM
Cheap or not... **** works... they are robust and in the quuickest FWD outlaw car in the country/world
In fact they are in a number of record holding cars.
Good enough for me.
Old May 23, 2013 | 10:05 AM
sshh's Avatar
Who is doing GE sleeves (or full build) and ship worldwide?
thanks
Old May 23, 2013 | 10:29 AM
AFH-Parts's Avatar
They should. That is a pet peeve of mine. PSI is not a variable in determining the integrity of a component. A T3 and an SC61 of similar trims will make far different power at an equivalent boost pressure.
The real question is what kind of air volume said component can reliably handle. There seems to be no consistant standardized test for accurately determining "flow" ratings.
Old May 23, 2013 | 12:59 PM
Divers's Avatar
What do you mean by "Benson/Darton"?
Old May 23, 2013 | 02:23 PM
Last I heard Bensons sleeves were MFGd by Darton to "his spec" or whatever.
Actually Earl himself told me that IIRC.
Old May 23, 2013 | 03:51 PM
Nikos's Avatar
These are some pics of my visti to the ERL manufacturing plant from a few years ago. At the time they employed around 90-100 people. They are big in marine and auto.
For any questions you have you can email seth@erpperformance.com or sean@erlperformance.com They have always been great to worth with. Good luck with your engine. I am sharing these pics to get an idea what short of a manufacturing facility they are running, it goes beyond what we call a shop.
HotWheelz
Jun 28, 2021 02:17 PM
McLude2nRR
Oct 20, 2005 11:34 AM
djnikko
May 1, 2005 06:32 AM
Purelude
Aug 6, 2001 07:02 PM
