Pull OBD1 codes with no gauge cluster?
Old May 21, 2013 | 08:18 AM
johnny hatchback's Avatar
Default Pull OBD1 codes with no gauge cluster?
I have a prelude that is a full on racecar, and i don't mean a drag car that you drive home... i mean no windows, no dash, nothing. The wiring is there but there is no dash or cluster and I don't have access to one.
Is there a way to pull codes without the gauge cluster?
Old May 24, 2013 | 08:08 PM
thirsk66's Avatar
Default Re: Pull OBD1 codes with no gauge cluster?
The guys below me seem to have solved your problem for you. Hope it all works out for you.
Goodluck with your issue.
Old May 24, 2013 | 09:33 PM
silkypillows's Avatar
Do you have any auto electrical experience?
not sure if this is Kosher, but you can probe the CEL wire in the harness with a multimeter.
looking for ~12vdc solid or down/up.(solid or blinking cel)
a light bulb could also be wired up using the same components as would be in the cluster, if you can find a diagram.
Old May 25, 2013 | 05:13 AM
yroachy's Avatar
Blue white wire in pin a13 on obd1 ecu turns the check engine light on and off. I would wire a bulb up instead of using a multimeter. Easier to count the flashes.
Bruce Banner
Mar 13, 2008 12:00 AM
Mister Jew
Sep 22, 2006 05:55 PM
hedtrip
15
May 22, 2006 08:02 PM
birz
Feb 27, 2005 01:48 PM
CMCivicSI
May 20, 2004 04:24 PM
