schrader valve stuck in spark plug well ! need help.
Old May 20, 2013 | 01:57 PM
B_Swapped93's Avatar
Default schrader valve stuck in spark plug well ! need help.
I'm really stuck on this one the valve part is round on the outside so I can't use any sort of socket the hose part let go. here's the pics.
Old May 20, 2013 | 03:29 PM
1998GsRIntegra's Avatar
Default Re: schrader valve stuck in spark plug well ! need help.
What have you done now? I assume that's off of a compression tester?
Old May 20, 2013 | 03:48 PM
yup, it's from a compression tester. this is a real problem nothing on here about someone messing up a comp test to the degree that being said the tester was 21$
Old May 20, 2013 | 04:01 PM
DELuth's Avatar
Take the core out and take a drill bit to it from the cylinder side. When the bit catches, it might spin it out.
I hope you didn't have to take the head off for that. I get them out with pliers like these. I've even had it happen with a new Mac compression tester, so don't beat yourself up for buying a cheap one.
Old May 20, 2013 | 04:13 PM
i'm scared of screwing up the threads if I try to bore it out as that will happen if the bit doesn't catch. the ONLY part I could grip is a small nipple that the hose went on and those plyers won't be able to offer enough grip. it's pretty snug in there. yes that's why the head is off because drilling/boring will drop metal bits/shavings into the cyl it's self i can't have that !
Old May 20, 2013 | 04:22 PM
DELuth's Avatar
It's probably just stuck on the o-ring. Spray some silicone down the plug tower and twist that sucker. Don't use a huge drill bit, just big enough to get a good bite. You have plenty of metal to work with there.
Old May 20, 2013 | 04:30 PM
It is in there tighter than I probably should have made it, but I've done this many times before(same tester). the engine was hot when I was doing this of course I pured oil down the tube no joy I finally ripped off the hose off to see if it had a socket bottom. will try plyers and reconnecting the hose.
Old May 20, 2013 | 04:53 PM
Well, I guess I would drill out the schrader valve and then tap the resulting hole for a 10mm bolt. Thread the bolt in and start tightening it with a socket. That will back the entire thing out the top of the head as if you were removing it from the top side.
On second thought, a 10mm is probably to big...
I guess try to drill it out and hope the drill bit catches and rotates the thing out.
Old May 20, 2013 | 04:59 PM
Got it !! got my needle nose pliers and stuck one of the prongs in the valve it's self then turned it. FFS now I need new coolant new oil new PS fluid and ofcourse a new tester should have tried this before removing the head....in my defense I was tired and hungover lol
edit:thanks DELuth saved me quite a bit of embarismeant and 30$ lol
Old May 21, 2013 | 08:12 AM
sleepyaccord96's Avatar
b swapped you get yourself into some odd **** man...lol
Old May 21, 2013 | 08:53 AM
DELuth's Avatar
Glad you got it.
Old May 21, 2013 | 12:14 PM
That was my thought as well. Lol
Old May 21, 2013 | 06:54 PM
DazeMS's Avatar
I will third that.. lol
BearsEK-KMSU
16
Mar 12, 2013 05:22 PM
gjbraun
Jun 18, 2012 10:57 AM
7808
Feb 20, 2006 09:04 PM
cxVtecC1
Feb 18, 2005 06:54 AM
street dreams
Nov 21, 2004 04:48 PM
