JDM ITR................What is the horsepower rating?
Old Oct 23, 2002 | 01:57 PM
Evil_Wizard's Avatar
Default JDM ITR................What is the horsepower rating?
200 or 210?
I say 210 on JDM ITR and
Slopoke says 200.
Which is it?
Old Oct 23, 2002 | 01:58 PM
Bbasso's Avatar
Default Re: JDM ITR................What is the horsepower rating? (Extreme_Hybrid_Hatch)
did you try a search first? this was just discussed a week ago.
Old Oct 23, 2002 | 02:01 PM
sgT's Avatar
sgT
you are WRONG
Old Oct 23, 2002 | 02:11 PM
Chris N's Avatar
Which is it?
Neither.
Old Oct 23, 2002 | 02:19 PM
AccrdATK's Avatar
New User
Default Re: JDM ITR................What is the horsepower rating? (sgT)
what is the hp rating then?
Old Oct 23, 2002 | 02:37 PM
Jin Yamato's Avatar
Default Re: JDM ITR................What is the horsepower rating? (CoreysTypeR)
195?
Old Oct 23, 2002 | 02:43 PM
Asahi's Avatar
200ps which is approx 197 hp
edit: for DC2R.
[Modified by Asahi, 5:43 PM 10/23/2002]
Old Oct 23, 2002 | 02:45 PM
Chris N's Avatar
Default Re: JDM ITR................What is the horsepower rating? (Asahi)
200ps - 197 hp.
Edit: got beat to it!
[Modified by 1107, 5:45 PM 10/23/2002]
Old Oct 23, 2002 | 03:02 PM
2001TypeR's Avatar
Well which year JDM ITR???? ours is 197 hp, but its hard to tell with ITR's cause they gain more as they break in....The JDM 98+ i thought was 210 also, it makes no sense that it has the 4-1 header and bigger exhaust, higher comp and its the same or close to it? thats makes no sense....but then again they run the same stock intake so it maybe doesn't make as much as it should.....
PS. Actually i saw a dyno of a jdm stock one and us stock one, the jdm was 169 whp, the us was 162 whp both bone stock brand new....but then again lots fo factors could change numbers so that might not be right, but it sure sounds right for the differences
Old Oct 23, 2002 | 03:20 PM
Default Re: JDM ITR................What is the horsepower rating? (2001TypeR)
Ok now Honda's lose about 17 percent loss through the drivetrain and at
210 with the 17 percent factored in it is like 174.3
205 with 17 percent loss iit is 170.15
200 with the 17 percent it is 166
So that tells me that The JDM makesbetween 205-210
Old Oct 23, 2002 | 03:28 PM
RICHJ's Avatar
98+ JDM = 200PS = approx 197BHP
From the horses mouth:
http://www.honda.co.jp/HOT/ModelData...ata/index.html
Spec is for 98on (check out the gear ratios and 16inch wheels)
Old Oct 23, 2002 | 03:42 PM
Asahi's Avatar
Problem with that is those are in PS not HP.
Old Oct 23, 2002 | 03:57 PM
92TypeR's Avatar
FSAE
Also, manufacturers use an engine dynometer, so they measure the HP of the engine, that doesn't include the 4-1 header and exhaust.
Old Oct 23, 2002 | 04:18 PM
2001TypeR's Avatar
Default Re: JDM ITR................What is the horsepower rating? (92TypeR)
oh well thats that why lol
Old Oct 23, 2002 | 05:24 PM
BERT-O's Avatar
hell, screw all the guess work. why don't you buy one and dyno it. then we all know for sure.
Old Oct 23, 2002 | 06:43 PM
Hooch'n's Avatar
Default Re: JDM ITR................What is the horsepower rating? (SANBST)
sounds good to me.............197 sounds about right to me.
sbcs15
Jan 20, 2006 01:59 PM
Steve-o
Sep 16, 2004 02:32 PM
Rdriver
Dec 14, 2001 01:11 PM
AL
Dec 3, 2001 09:26 PM
