DC4 Sounds Bad Man and Loses Magic Green Liquid
Another noob with a problem needs help diagnosing his problem.
My Background: I am a fairly handy chap, I enrolled in the Auto Tech program at my local JuCo after high school. I finished one year but left the program after discovering that I suck at diagnosis. Seriously, I disassembled almost an entire engine over a bad fuel filter in class.
The Car: I retrieved a 1995 Acura Integra SE 1.8L B18B1 (non Vtec
) from a bloke two weeks ago. I noticed the coolant was green when I purchased it.
We checked compression and it was 180 - 150 - 170 - 180 (the engine was warm)
The Problem: Yesterday while cruising down the road I heard a strange sound, it sounded like woo-oo. I slowed down and the noise stopped, so it was not speed dependent. I saw that the next exit was 1/2 a mile, so I put on my hazards and slowly made my way to the off ramp. When I got to the light at the end of the ramp the noise was louder more like a roar. When I went to accelerate to get to the gas station half a block away the noise was terrible, like something was caught in my engine, so when I came to a stop and then accelerated again it was the worst. As soon as I pulled in the gas station I cut the car off and watched a decent sized puddle form in front of the driver side tire, it was engine coolant.
I called my local tow jockey and he came to get me. He cranked the car said it was drive able (for a short distance) and drove it on to his truck. At his shop he quoted me for a timing belt and water pump. I had him tow in to my house and had a 'mobile' mechanic come by this morning. He diagnosed the same thing.
The second mechanic did a COLD compression test and got 180 - 150 - 150 - 120.
Neither of these fine gentlemen are Honda/Acura specialists so what do you think?
Pictures: Will be up once my lazy brother returns my camera.
More Information: Is available at your request ask and I shall go get you anything you need to know.
Thanks: I have a few measly dollars in my Paypal for clear and well reasoned answers.
) from a bloke two weeks ago. I noticed the coolant was green when I purchased it.We checked compression and it was 180 - 150 - 170 - 180 (the engine was warm)
The interesting thing about it is the temperature gauge never shot up. It stay around the half way mark the whole time.
Shot a video while the mechanic had it running. http://www.youtube.com/watch?v=NxPCa...ature=youtu.be
As far as tracing the leak I have not, I was chased inside by the rain. I will get the VC and timing cover off if it subsides.
Last edited by bdlawnic; May 19, 2013 at 09:50 AM. Reason: Still Suck At Speeling...
Might just be a coincidence. that noise makes me think of a loose rocker or a timing belat that is coming apart. Normally that wouldn't be associated with a coolant leak. Must diagnose more and find the noise source and the leak source when weather allows.
Did a little bit of work when the weather cleared. http://s497.photobucket.com/user/bdl...?sort=3&page=1
I am inside again...
I turned the crank by hand and everything seemed okay, the timing belt was a bit loose.
I am off to Sunday night family diner but I will be available after that but it will be dark by then.
Sorry for the double post but I goofed this morning. During the compression test I was inside the car while the mechanic was under the hood. I was bumping the starter but I did not have the throttle open.
I did the test 160 - 150 - 170 - 160. This was with a cold engine and the valve cover bolts only hand tight.
I will be bleeding the coolant system soon.
I will get a picture in the morning before work. Its going to be a bit slow working on the car this week with my crazy work schedule, but I will be using the long weekend ahead to fix it.
I see you most likely need a new water pump and a timing belt tensioner, rotate engine untill cam gears are up, do the maks line up or have you skipped a tooth? 94
Sorry to double post but the water pump was bad. I fell down some bloody stairs and had to take the car to a shop.
hai_kichaa
Nov 26, 2008 08:49 PM
gobengeo
18
Jun 24, 2004 10:41 PM
