Honda CR-V & Element 2WD & 4WD Element & CR-V
Pricing quote on lowering a Crv?
Old May 18, 2013 | 07:07 PM
Eric Buschman's Avatar
Default Pricing quote on lowering a Crv?
Hey all. I was wondering if you guys would be able to tell me if this is a good price or not for installing new shocks on my crv. I'll post the email that I got from Tachyon Performance in louisville
"Eric,
Labor will be 4.25 hours @ $75 an hour to replace the springs and
shocks/struts. Springs will be around two hundred dollars. Shocks will be
around $150-$180 a piece. So, your total without an alignment will be around
$1238. We recommend Bilstein or Koni shocks.
Another option is to replace only the shocks with Koni yellow Sport shocks
which have adjustable spring height perches. This would enable you to just
keep the stock springs, lower the car, keep a good ride, but increase the
handling tremendously. This is the setup I have on my Civic. The price would
be the same only without the cost of the springs."
Does this seem like a good deal or not? I'm not looking to cheap out on suspension work, I just don't want to over pay if I don't have to. Any help you could give would be great! Thanks in advance!
Old May 18, 2013 | 11:05 PM
ARMED's Avatar
Default Re: Pricing quote on lowering a Crv?
not....
Old May 19, 2013 | 01:11 AM
wolfy47's Avatar
Its a bad deal (at least here in socal)
Just to give you an idea, my friend was quoted by a local honda specialist shop $150 for 4 coilovers installed and adjust to his desired height on top of the $560 he paid for his F&F type 1's from the same shop for his civic
If you feel confident in yourself, you still can always install the suspension yourself
I have a newer accord, that I have only owned for a little over a month so it is unfamiliar to me, and I just installed some coilovers in a little under 4 hours with jack stands and a air gun
Old May 19, 2013 | 04:10 AM
Sticker Bomb's Avatar
Don't do it. Pick your self up a set of full coilovers, you'll be way happier with them. I have a set of F&F type 2 from a 94-01 Integra in mine, and it rides a lot better then just springs and strut combo.
Old May 19, 2013 | 08:17 AM
Skillachie's Avatar
I would just buy the coilovers and install them myself
Old May 19, 2013 | 05:44 PM
Aha! I thought it was a little pricey. Thanks for the input guys, saves me a lot of headaches and regret.
Old May 20, 2013 | 08:29 AM
How hard is that to do? I'm extremely new to cars, I haven't even learned how to change spark plugs yet lol.
Old May 20, 2013 | 10:48 AM
dogbiscuit's Avatar
It's usually not the doing that caused me problems when learning stuff. It's having proper tolls. and proper tools cost money.
Old May 20, 2013 | 01:07 PM
It's not hard at all, but like what has been said, knowing how to do it, you need to know what to do and what order. I would help you, but you are a little far away lol
Old May 20, 2013 | 01:41 PM
77777's Avatar
yeah you can have your choice of coilovers for that. realistically you can get ksport springs for like 100, kybs for under 400, and even with labor it would be half what they quoted. the cr-v i found to be a bit of a pita changing springs so i would recommend coilovers because of that and the ability to go lower. but suspension on hondas is easy, no need to throw money away paying labor especially for coilovers. we are talking literally like 3 bolts a corner.
Old May 20, 2013 | 07:31 PM
Thanks for all the responses! I have a quick question though, do the coilovers have to be made specifically for the crv or can they be made for a jetta/golf? Found some pretty good deals on craigslist.
Old May 21, 2013 | 04:48 AM
shermanyang's Avatar
you'd want some specifically made for the CRVs for best results. You can rig suspension from other vehicles to fit, but it's going to be a hit or miss.
Old May 21, 2013 | 06:38 AM
boliviansol's Avatar
If you were willing to pay $1,238 as u stated on ur original post. Than u should buy the fortune auto coilovers made for the crv. They are currently THE BEST direct bolt on set up on the market.
Old May 21, 2013 | 06:42 AM
Skillachie's Avatar
thats the word in the streets sir
But holy moly its expensive @ $1600 & $1200
What about D2 @ $900
Old May 21, 2013 | 07:35 AM
U gotta pay to play !
They are going to be my next set up once my konis give out .
Old May 21, 2013 | 09:05 AM
Skillachie's Avatar
I here yah, but it still sucks that theyre mad expensive thou
Old May 21, 2013 | 01:39 PM
dpapichulo718's Avatar
Wazup man if you looking to lower your crv i could get you d2 for $850 we could also ship to u @project jdm just call the store @718-424-7280 and ask for luis
ehmarc
Jun 25, 2007 12:47 PM
slowman
Oct 27, 2002 10:09 AM
Eddoes
Aug 16, 2002 11:44 AM
tjtruong
Oct 28, 2001 06:16 PM
