95 civic d16 gets boost but no power
Old May 16, 2013 | 08:00 PM
V-Nonyak's Avatar
Default 95 civic d16 gets boost but no power
Hello ht I have a 95 eg with a d16y8 it's bottom end built and I'm pushing 26 pounds but after changing the PVC valves head gasket and valve seals I'm not getting the power I used too it builds up boost way faster then it used to used to be full boost at 5.6 rpm but now at like 3 and it feels like there is no power at all anyone have this before? It's almost like timing but I checked it and its in
|||. | Were the dot is and dizzy is a bit advanced as well so idk help me out!
Old May 17, 2013 | 02:59 AM
grumblemarc's Avatar
The Grumpiest
Default Re: 95 civic d16 gets boost but no power
Holy lack of info Batman!
Old May 17, 2013 | 08:44 AM
V-Nonyak's Avatar
What other info would you need?
Old May 17, 2013 | 09:16 AM
5speed4life's Avatar
Tripple check your cam timing. If you have an adjustable cam gear, make sure it didn't slip either.
Old May 17, 2013 | 09:44 AM
Schister66's Avatar
Man U FTW
It'd be helpful to know about the setup, who tuned it, what it was tuned on, etc... Do you have fuel/timing maps or the graph of AFRs from the dyno?
Old May 17, 2013 | 10:56 AM
V-Nonyak's Avatar
I'm playing with the timing right now and it kinda seems like that's the prob. But anyways he setup is a built bottom end y8 eagle h beam rods and low comp vitara pistons with a 67 trim turbo setup everything ran great befor I changed the head gasket and valve seals and PVC valves it smoked like hell at idle but I after I changed all that the smoking stopped but now it's got no power but builds full boost?
Old May 17, 2013 | 07:08 PM
V-Nonyak's Avatar
It was timing! Got it all good now have no timing covers on motor so I was winging it every time and finally got it thanks for all the help
Blown90hatcH
Apr 21, 2005 01:27 PM
Turbo E
Nov 3, 2004 10:13 AM
pinche
Sep 7, 2004 03:56 PM
airborne84000
Apr 30, 2003 07:07 AM
Boosted B18C5
Nov 21, 2002 02:27 PM
