welding stock tranny bracket back on(been cut off for kswap)
so has anyone welded the stock tranny bracket mount back on
going h2b but previous has cut the tranny bracket mount off
Those mounts are "spot" welded. Im not really sure what your question is here? I assume you want to know the best way to re install the mount? Do you already have a mount to weld in? Post some pictures of the mount and the frame rail so that I can give you advice. Depending on how it was removed will determine the best option for re install.
Mount it farther back and higher up - do all three the same way - to account for lowering the car, and to move the weight as far rearward as possible.
le0ftw
Jun 4, 2009 02:44 PM
97civicdx
Feb 9, 2005 12:32 PM
Dyzee
Mar 16, 2004 12:02 PM
Will Albers
Sep 30, 2002 08:03 AM
