Clutch
My car went into the shop for the JDM front the day I got the Clutchmaster Stage 3 installed. After sitting for 3-4 months, I was never able to really break it in. I am doing that now. A few issues:
#1 - when i lift the clutch after shifting, I get a click noise. almost like the sound you hear when the Tin Man gets oiled in the Wizard of Oz (if that helps
#2 - how long is it recommended that I break in the clutch, and what does the breakin period consist of?
Thanks,
jon
). #2 - how long is it recommended that I break in the clutch, and what does the breakin period consist of?
Thanks,
jon
It shouldn't damage the clutch. The lubrication needed is between the bearing bore and the transmission drive shaft so the bearing travels smoothly back and foward when you push and release the clutch pedal.
Sometimes the "click" you feel just goes away on its own...
Solstic
Jun 13, 2012 11:34 AM
