NO SPARK
Old May 15, 2013 | 04:32 PM
dwils's Avatar
Default NO SPARK
i currently have 1990 dx hatch with a 94 ls in it. i converted it to multi point and obd1. i have fuel pressure and car cranks but there is no spark. ive changed distributor. I also have ecu code 20. what could be my issue. thanks!
Old May 15, 2013 | 07:57 PM
Z0831xiz's Avatar
okay what ever is wrong with your **** is wrong with mine!!! i have the same problem. fuel pressure is there. main relay is good. ecu is good. (gave me error 20) car just cranks for ages. I was told its my diZzy... unsure though haven't changed dizzy yet - broke -
Posted from Honda-tech.com App for Android
Old May 15, 2013 | 09:46 PM
BYOB916's Avatar
Default Re: NO SPARK
Make sure your ecu is obd1 ls and main relay is good
Old May 16, 2013 | 05:01 AM
dwils's Avatar
both ecu and main relay is good. i even tried my boys ecu that he has in his car and still no spark
Old May 16, 2013 | 07:16 AM
Crxcam's Avatar
Check ignition fuse, check battery for fused link from your battery wire, and one thing a lot of people overlook is the resistor box and the tps wire swap, reread the how tos on dpfi to mpfi make 100% sure everything is in place
TheWhopper
May 8, 2019 05:59 AM
winquest1000
Jun 30, 2014 10:10 AM
4gen5thtime
Apr 23, 2009 01:09 PM
white90rexsi
10
Jun 28, 2007 02:50 PM
C8V6C
Jan 29, 2004 11:18 PM
