300hp boost build - overbore
Old May 15, 2013 | 04:14 PM
GT500FTW's Avatar
Default 300hp boost build - overbore
Hey guys.
I've got a dilemma.
I'm wanting 300hp from my b16a2. I'm running a medium sized ball bearing turbo.
I'm rebuilding my block, but I've got 2 choices.
1 - I have a block with a recent 0.5mm overbore and fresh hone. I have srp pistons and eagle rods for this block.
Or 2 - I have a stock block with stock pistons and rods.
I'm worried that the 0.5mm overbore will weaken the cylinders too much, and I don't want to blow it up.
Any suggestions?
Old May 15, 2013 | 04:22 PM
sanman000719's Avatar
Default Re: 300hp boost build - overbore
stock block will handle 300whp in its sleep man
as long as you check everything and ensure your good.
600whp has been made off a stock b16 block.
Old May 15, 2013 | 04:41 PM
GT500FTW's Avatar
So you say that stock block with stock pistons and rods is the way to go then?
I have arp main and head studs ready to go too.
Old May 15, 2013 | 04:52 PM
for the power you want ide say yes man that way if you mess it up its what $500 for a short block lol.
Old May 15, 2013 | 04:56 PM
datbumper's Avatar
Plus all the money in parts you put into it. But yea, if you're only aiming for 300hp, just use the stock block. I wouldn't use the over-bored one if I were in your position, mostly for the sake of mind, but also on the off-chance that boring it at would weaken the cylinder walls just enough for them to crack.
Old May 15, 2013 | 06:08 PM
Muckman's Avatar
Moderator in Chief
Sanman is right the stock block can safely make that power. But I also dont think 0.5mm bore is anything to lose sleep over either. Ask that question to the B20 kids and you'd get a different answer.
Old May 15, 2013 | 06:51 PM
th3pwn3r's Avatar
How long do you think you could make that power before something goes wrong?
Old May 16, 2013 | 05:36 AM
3 years now and going and not the only one to do it either
the question you should ask is how long would an idiot when it comes to driving expect to have that block stay together
Old May 16, 2013 | 09:27 AM
datbumper's Avatar
Well if you drive like an idiot and want to go fast, you shouldn't be running on a turbo'd stock block then. lol
Old May 16, 2013 | 10:19 AM
says the uneducated man trying to sound like a champ
being on the track trying to achieve something isnt the same as being a ******* idiot on the street.
go back to school kid
Old May 16, 2013 | 10:27 AM
grumblemarc's Avatar
The Grumpiest
Hm. Putting a turbo on a car to go faster is dumb. I guess I've been doing it wrong all this time. No man here. 19 year old.
thugsbryan
Mar 27, 2015 09:48 AM
GT500FTW
Nov 3, 2014 02:32 PM
lsvtecturbosol
May 23, 2009 02:07 PM
TDogg Teg
May 15, 2008 09:34 AM
killacam661
Nov 26, 2007 12:35 PM
