Scraping noise coming from wheel
Old May 15, 2013 | 02:32 PM
sSandstorm's Avatar
Default Scraping noise coming from wheel
I've been having a weird scraping noise since I gave my very tall, large brother (320lbs) a ride. It's a tsk...tsk...tsk... noise, and it increases in frequency with speed but stops around 40-50 mph, and becomes more random, or stops. I tried taking the wheel off and spinning the hub, without any noise, but when I bolt the wheel on and spin it (on a jack) it makes the noise. Any thoughts?
Old May 15, 2013 | 02:56 PM
silkypillows's Avatar
Default Re: Scraping noise coming from wheel
sounds like a wheel bearing. is the sound there if the brake rotor/caliper is removed?
Old May 15, 2013 | 07:54 PM
DumpdEJ6's Avatar
I like the tuna here
It sounds like the rotor splash guard is coming into contact with the rotor. Check on the backside of the rotor and push the thin metal splash guard towards the center of the car just a little bit, and see if the noise goes away.
Old May 16, 2013 | 06:33 AM
strategy400's Avatar
worn brake pads?
Old May 20, 2013 | 12:19 PM
sSandstorm's Avatar
I'm pretty sure it's not the brakes or the splash guard. As I said before, it only happens with the wheel on, when I take the wheel off and spin it it goes away.
verycleanhatch
Suspension & Brakes
Sep 29, 2009 07:32 AM
do0d
Sep 20, 2008 07:53 PM
Lude Acts
Jan 24, 2008 05:25 AM
carbonlaced
Jun 27, 2006 10:02 AM
Everyones Hero
Feb 11, 2006 08:27 PM
