Piston rings going/gone. 94 gsr
Did a wet comp test as the car was supposed to get tuned this Thursday....shot up by 80-100psi for all 4 cyls. I know it's due to the car running rich AF for all that time. but here's my question CAN I pull the pistons to replace the rings WITHOUT pulling the engine it's self I don't have the know how to do all that. pls need some insight I know removing the entire engine would be easier but I don't have the time/tools.
Was brought to my attention that a "shots" worth of oil is too much
would that throw the reading off ? vs the proper table spoon amount ?
So I'm not an expert on wet tests, but based solely on what I know about fluid dynamics and general volume math, it seems it would affect it. So when you add oil to a cylinder, the total volume of the cylinder goes down by a certain volume. When that cylinder volume goes down, ( piston going up) if the oil doesn't leave, the final compressed volume is reduced by the same ammount. That small percentage reduction in initial volume does not compensate at all for the large percentage change in final volume. So what you end up with is almost the same amount of air compressed into a significantly reduced final volume. And using the old equation pv=nrt if nothing changes but volume, a ratio would prove that total pressure would go up a whole hell of a lot. Kinda like this. (numbers are made up for ease.) 1000cc :100 cc = 10:1 1000cc-10cc : 100cc-10cc =11:1 compression. If your inital dry test was in spec I wouldn't fret.
OK^
1 question: if the rings were completely "shot" 1 would my comp still be in the 215-222 area ? I burn NO oil at all so did I kinda drop the ball on this diagnosis so to say
As Blackhalo explains when you do a wet test, by adding fluid to the cylinder you also increase the compression ratio. Hence the average compression numbers go up in all cylinders. However, in cylinders with ring leaks, the compression ratio does not increase as much, so the compression increase is smaller. My hunch is that the more fluid you add, the more potential for a big difference in compression results. But if you think you used the wrong procedure just do it again. It only takes 20 min. to do a compression test... Just make sure you use EXACTLY the same amount of oil in each cylinder.
My thread might have some of your answers and might interest you.
https://honda-tech.com/forums/acura-integra-6/washed-out-piston-rings-how-long-can-i-drive-her-3127913/
say your thread a while back. I can by no means rip a block apart or pay to have it done will be re-doing wet test tomorrow with correct amount of oil this time. and post up the numbers.
Thanks sadly this happened before I could even try https://honda-tech.com/forums/acura-integra-6/schrader-valve-stuck-spark-plug-well-need-help-3146898/
hang on, burns no oil?
you need to do a warm compression test. oil in the cylinder will always raise compression numbers but does it more on a cold engine
get the engine to temp and do a compression test
i have NEVER seen an engine down substantially on compression that does not burn oil
If you pull the head and the bottom end apart, leaving the block in the car, you can unbolt the rods on the under side and slide the piston/rod out the top of the cylinder. You can hone the cylinders from the top and slide new pistons in, then bolt them back to the crank. Its a hassle to work around the crank, but is certainly possible.
but I do think I just scared my self by "doing it wrong"
hang on yet again
300 with oil in there is NORMAL, especially if it was a decent amount of oil
220-240 dry is also normal for a usdm gsr
before you tear your motor apart do a manifold vacuum test. if one cylinder is down on compression you will see flutter in the gauge. this tests takes 30 seconds and is very easy. you simply put the gauge on a vacuum line and watch
if the needle is stable you don't have a wide variance of compression
based on your posts you do not have the skill to re assemble the engine correctly and even if you did, i'm not seeing signs of anything wrong yet
hang on yet again
don't pull the fuel reg! brake booster can work, your iacv line from the manifold could work. basically anything except the fuel pressure vacuum line. where your pcv enters the intake manifold is another good one. whatever source you pull make sure it goes directly to the intake manifold unobstructed
harbor freight sells accurate vacuum gauges for $10, worth having in the tool box.
just make sure you have a decent seal so the engine idles correctly and gives you a good reading on the gauge
do this test with the engine warm
changing the rings aren't that hard. if you can pull a head and set the timing you can swap out piston rings. just make sure you take your time and have a piston ring compressor. good luck on the other thread. i would say drill it and use an extractor. that should do the trick.
on a scale of 1-10 how hard is that ? I consider pulling the head a 2 difficulty and a clutch job a 7-8. do I need to worry about main bearings or stuff like that or can I just unbolt,slide re-ring and maybe hone then bolt(TQ to spec) it all up
If you're patient and capable of keeping things clean, its a fairly simple process, albeit time consuming. Get some nitrile gloves, search the FAQ for the engine rebuild How To and get to work. I totally winged it my first time with the aide of the forums and that engine is still going strong (built LS/VTEC @ ~400whp)
B_Swapped93
14
May 15, 2013 03:19 PM
DumpdEJ6
Apr 25, 2010 08:35 PM
