TPS or Transmission issue?
Old May 14, 2013 | 05:48 PM
jerrussell1976's Avatar
Default TPS or Transmission issue?
I have a 1998 Honda Civic LX that is stalling and has a slight vibration issue. The car has 197,000 miles on it and it is an automatic. The car started out hesitating randomly. Then it started doing it more after the car was warmed up, and now it is pretty constant after it gets warmed up. I read a few forums talking about the TPS being the issue. What does everyone think it is TPS or transmission? If you think it is a TPS issue where is it located at and does anyone have any pictures of it?
Thanks for looking and any advice you can give me!!!!
Old May 14, 2013 | 06:24 PM
tony_2018's Avatar
Fish Twig
Default Re: TPS or Transmission issue?
Go for it....check the middle wire for voltage. should read .45, WOT should read 4.9.
Old May 15, 2013 | 05:57 AM
kyden's Avatar
when was the last tuneup?
Old May 15, 2013 | 07:22 AM
Lizardslap's Avatar
cant hurt to check the tps and this guy made a good write up for it
https://honda-tech.com/forums/tech-misc-15/diy-how-calibrating-voltage-your-tps-sensor-2947986/
Old May 15, 2013 | 06:13 PM
It has been a while since the last tuneup.
Old May 15, 2013 | 06:15 PM
https://honda-tech.com/forums/showthread.php?t=2947986
The write up looks awsome espicially for a weekend/non mechanic like me.
Thanks!!!!!
Old May 19, 2013 | 05:27 PM
I checked the voltage with the green wire being ground and the red wire as positive on the TPS. The voltage with key on the run postion and engine off was .43V and with the accelorator pressed it was 4.3V. With the engine on and warmed up at idele the volts were .43V and with car at 6000 RPMs I could not get a reading. Did I do this right and is the TPS bad?
Old Aug 28, 2013 | 12:05 PM
Ertavarez's Avatar
I have the same problem, i bought a new TPS and still the same problem, this is annoying
Brandon Hartman
Nov 21, 2018 02:03 PM
sgnlab
Oct 14, 2009 03:57 AM
95lstegman
Jan 13, 2005 08:04 AM
Hybrid CRX
Jan 19, 2004 01:56 PM
