B16 crank cog removal.
Old May 13, 2013 | 03:40 PM
GT500FTW's Avatar
Default B16 crank cog removal.
Hey guys. I'm removing my crank, but I'm having trouble getting the crankshaft cog off.
Any tips? Or am I going to have to get a gear puller?
Thanks.
Old May 13, 2013 | 03:48 PM
ElectronBlue00's Avatar
Default Re: B16 crank cog removal.
Thanks.
By Crankshaft Cog i'm assuming you mean the timing belt drive pulley. (also known as a sprocket)
This should be easily removed. But I must ask, did you remove the timing belt already?
Old May 13, 2013 | 03:57 PM
GT500FTW's Avatar
Correct, the timing belt drive sprocket/cog. I wouldn't describe it as a pulley.
Seems like a strange question to ask, but yes, the timing belt has been removed.
Would you suggest using a couple of screwdrivers ? I don't want to damage it.
Old May 13, 2013 | 04:03 PM
silkypillows's Avatar
there are quite a few ways to do it, but i would look in to getting the proper removal tool. it's the safest way.
check out your local auto parts store. they can probably rent it to you.
Old May 13, 2013 | 04:38 PM
Okay. I had the same issue. The only thing I had to do was squeeze a screw driver between the crank case and the sprocket gently. And tapped it lightly and it popped off. I wouldn't use to much force though.
MTswisher
Jul 14, 2018 09:31 PM
us31wking
Aug 21, 2014 04:50 AM
Vtran4600
Jun 22, 2009 08:54 PM
mattyturbo
Dec 8, 2007 12:55 PM
Civiclx
Nov 30, 2003 01:52 PM
