turbo d16z6, blew the headgasket...again
Old May 13, 2013 | 10:11 AM
boarding2008's Avatar
Default turbo d16z6, blew the headgasket...again
so the first time i blew the head gasket i am going to blame it on the cheap eBay/unknown branded head gasket. i bought new arps and an oem gasket from Honda and that lasted from early august or so of last year until 3 days ago. from searching around on Google it seems head lift is a common ailment of these engines. both times the head gasket blew it was pushing coolant, never mixed oil and coolant. does anyone know of a way to cure this? some are saying getting the block/head ringed.
my setup:
75.5 srp pistons
eagle rods
arp rod bolts
acl race bearings
arp head studs
stock head minus a mild PnP and 3 angle
im running 20psi on a t3t4 57 trim, ramhorn manifold, tial BOV and 38mm wastegate. i plan on taking the engine out anyway because the car is getting painted, so in the mean time i figured i would build the head (cam, springs, retainers and a bettter PnP) while its out because if i can hit the same numbers while turning down the boost this should be less stressful on my engine, am i right?
CLIFFS:
2nd headgasket blown on mildly built d16z6
i know headlift is a common problem
how can i fix this? - ringing the head/block
will building my head to hit the same numbers at a lower psi be less stressful on an engine'
thanks in advance
Old May 13, 2013 | 10:37 AM
kyden's Avatar
Default Re: turbo d16z6, blew the headgasket...again
it's all about timing when it comes to a d series. who tuned it?
Old May 13, 2013 | 11:19 AM
jon donovan who is local to me. he has tuned a broad range of cars (ie mustangs, turbo bmws, honda, etc)
Old May 20, 2013 | 11:35 AM
integlspwr2k's Avatar
headlift is a known problem but not sure if two head gasksets on the same engine is to blame. Look into the tune...
Old May 20, 2013 | 11:53 AM
lsturbo33's Avatar
Did you deck the head?
Old May 20, 2013 | 12:22 PM
jimbo slice's Avatar
Did you have the block resurfaced also? I've had a block with .004 deviation and it caused the coolant to push out of the reservoir when in boost. Normal driving it ran fine, never once overheating
Old May 22, 2013 | 06:15 AM
HondaPro1's Avatar
nice pointers tho, just no fuel? what pressure should you run on 8 lbs?
Old May 22, 2013 | 01:27 PM
That video has nothing to do with this thread
Fuel pressure is only one aspect to address when turbocharging a Honda.
Old May 22, 2013 | 03:41 PM
nealnanoHX's Avatar
Yeah did you have the head check to make sure it is still flat? After blowing a head gasket I always have the head checked and repaired if needed. I would the car retuned elsewhere as well.
Old May 23, 2013 | 12:19 AM
Discosteak's Avatar
check the head and block surface with a straightedge. it sounds like one or both are warped.
Old May 23, 2013 | 07:39 PM
red96turbols's Avatar
Ever think about fire rings??
Old May 24, 2013 | 04:19 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
They are built into the headgasket... Do you mean O-rings?
NIKADEM0
Nov 16, 2014 09:39 AM
Tong.Y
Jun 5, 2011 09:17 PM
HackeN
Jul 19, 2006 06:23 PM
99lspwr
Oct 3, 2004 05:33 PM
integracivic94
Jan 7, 2004 11:56 AM
