TPS issue*
Old May 12, 2013 | 06:14 PM
2000EKCoupe's Avatar
10 Year Member
Default TPS issue*
im having an issue with my tps voltage. I have an omni power 68mm throttle body with aftermarket tps. Im using a p28 chipped ecu with my obd2 engine harness that came factory from my coupe.
I back probed the sensor and got my .5v at closed throttle and only 3.4v at wide open throttle, at the max adjustment. I also have CEL that flashes 7 times which is the tps sensor. Im not sure where to go from here and i need some assistance.
Old May 12, 2013 | 06:18 PM
B_Swapped93's Avatar
Default Re: TPS issue*
replace tps try again they're pretty cheap so might as well. try a diffenent ECU first if you can tho.
Old May 12, 2013 | 06:30 PM
10 Year Member
i changed it once already and it still codes. i deleted my o2 and knock sensor on this ecu. I have an obd2 ecu i can try. and i also bought another one off inline four just in case. i may try a oem throttle too if i can find one.
Old May 12, 2013 | 06:38 PM
Haven't heard of this issue with Omni Tb's before or any for that matter. when you say disable what are we talking s300 RTP or chrome ?
Old May 12, 2013 | 06:51 PM
10 Year Member
xenocron chipped the ecu. I think it may be the throttle body. i need one to swap out or an oem sensor
Old May 13, 2013 | 11:05 AM
xenocron's Avatar
.5 closed and 3.5 open should be fine...in Crome you cant really setup the 0 and 100% points quite as nicely as you can with Hondata, Neptune or eCtune...it may just be this.
Does the code come on right away or after you start and run the vehicle?
Generally you dont get a TPS CEL unless the sensor faults high or low (0 volts or 5 volts)
Old May 13, 2013 | 05:31 PM
10 Year Member
yea the code comes on right away as soon as i turn on the car. i also have a stepdown harness, idk if i have to swap and wires or anything.
Old May 14, 2013 | 12:06 PM
10 Year Member
any ideas?
Old May 14, 2013 | 03:10 PM
xenocron's Avatar
any ideas?
if you can see the correct voltages at the ECU for the TPS, then you might be seeing the wrong code blink out...
Old May 14, 2013 | 06:09 PM
10 Year Member
okay, ill check the voltages at the ecu. are there any diagrams for this?
Old May 15, 2013 | 10:00 AM
xenocron's Avatar
Just factory wiring diagrams
Old May 15, 2013 | 12:54 PM
10 Year Member
Thanks alot, ill check them over
shutta
Apr 5, 2007 04:46 AM
1000_miles
Dec 20, 2006 03:28 PM
Orangedragone
18
Sep 14, 2006 02:52 PM
frog169
Aug 4, 2006 12:18 PM
DanishR
May 14, 2005 11:05 AM
