Quick question: Will B16A/B header fit on B20B swap into eg si?
Old May 11, 2013 | 12:02 PM
PaChiLa Leader's Avatar
Icon6 Quick question: Will B16A/B header fit on B20B swap into eg si?
i have searched, but can't really seem to find the right answer on the B20B/Z block
i am about to do a JDM B20B (high comp) swap into my stock eg si and wondering which header would fit.
i want to go cheapest way possible to get the swap done and upgrade the whole exhaust sometime later down the road
I would like to know if B16A or B16B header would fit on stock B20B motor and without any clearance issue to either oil pan/ cross member.
need a def answer since i can access to get an unknown year JDM header
anyone knows the answer please shoot.
or whats the actual measurement or height i need to check on the header before i buy it
i have no way telling if the header was from b16 or b18
thanks
According to this
Old May 11, 2013 | 01:28 PM
EsotericImage's Avatar
Retired Moderator
Default Re: Quick question: Will B16A/B header fit on B20B swap into eg si?
Are you trying to stay with OEM ?
Any Bseries header will work. If it doesnt, the exhaust shop will make it work. Even aftermarket/knockoffs.
Old May 14, 2013 | 02:30 AM
yes sir, i am trying to stay OEM for now before i start modding it
my stock form eg si still rolls with stock suspension so bolt-ons will come after my brakes/suspension setup
so B16A/B & JDM 4-2-1 will def fit right??
Old Jun 22, 2013 | 09:48 PM
can anyone confirm the B16A header fits on stock JDM B20b?
MY NEW HEADER WONT' BE IN TILL MID OF jULY SO I NEED SOMETHING TO GET THE CAR GOING DOURING MEAN TIME
THANKS A LOT
Old Jun 22, 2013 | 09:54 PM
slowDB7's Avatar
i know the header from 99-00 si's will fit and bolt up fine, to head and your cat
i dont remember off the top of my head which b16 engine is in it
Old Jun 22, 2013 | 10:02 PM
doood's Avatar
been there done that
the deck height differences will make it a tight fit under the oil pan
Old Jun 22, 2013 | 10:59 PM
peteyparado's Avatar
all b-series bolt to the head.depends on the flange angle on the cat end,or if u have an 02 bung on the header down pipe or on the cat side or both.
Old Jun 29, 2013 | 08:40 AM
B16A won't work i know that
so B16A2 (slowDB7) might work
um...
thanks guys
Old Jun 29, 2013 | 08:30 PM
Retired Moderator
crazyguy
Jul 26, 2007 06:41 AM
Honda Sport
Aug 6, 2005 01:47 AM
morepoop4u
Jun 11, 2002 04:29 PM
