will a jdm itr 4.7 fd final drive fit in a b16
in what oem car can i find a 4.7 final drive for b series? im loking to order one from honda/acura and im not sure which vehicle and year had them stock thanks guys
I'm pretty sure US ITR only had 4.4 The only 4.7 came from 98+ JDM ITR's.
The 4.7 is nice, the 4th and 5th gears are the same as GSR to make up for it tho. But the 98+ with 4.7 has the shortest 1-3 gearing.
I just did a **** ton of reading on these trannies cuz I got a 98+ spec with 4.7 for $300 and had to rebuild 3/4 of it. I now have $1200 into it.
I would order one from m factor. Probably cheaper and a better gear . The itr 4.7 only comes in trannys from japan and they take a special first gear different from any other b series tranny even though its the same ratio. Im guessing you will want to run a higher first gear and it would be alot easier to just get a final drive and first gear from m factor. If you already have a first gear dont order a factory 4.7 or you want be able to use the first gear that you have now. Just trying to help man i build about ten trannys a week.
gsr I believe I had a b16 ls and a broken type r trans to make one LSD ended. up buying a gsr and swapped LSD ur best bet is like f20b Jones said mfactory they got great stuff
The OEM 4.7 will only work with GSR, ITR, and CTR differentials.
You will need to order an aftermarket FD like an MFactory if you want to use your B16A diff.
Black R
Oct 14, 2002 09:51 AM
