Reverse Flush Transmission Torture
My 98 EX auto transmission is already toast, so I have decided to abuse it with a reverse flush of Lucus laden fluid. A reman. unit is being reviewed by the Secretary of War and Finance (wife) for budget approval.
The idea is to force the mixture in reverse back through the input line to the cooler with a pump while operating the solenoids using 12 vdc.
The drain plug will remain out, and I'll catch the fluid and filter it to observe what comes out.
I suspect that the internal screens/filters are clogged with very fine clutch material.
Anyone care to add to or comment on this form of transmission abuse?
Meh, I don't think you will get the results you want.
Easier to just pull the shift solenoids apart and clean the screens manually. There is the sump filter, but if that is clogged rather than reverse flush(which I don't think will work), use Sea Foams Tran Tune instead.
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
I think he said it's already toast and being replaced. he just wants to see what comes out, on this, go big or go home, hook the SOB to the output of a pressure washer, complete with soap, LOL
do something fun, get going at a good clip, and throw it into park a few times, then flush, I want to see what comes out, have some fun destroying it , it's junk anyway right?
#16 is the parking pawl, it is spring loaded and will most likely just bouce off the parking pawl gear. But if it were to break off and then jam between the shaft gears, all manner of bad ju ju would happen. Park is similar to Neutral, but with a parking pawl.
Hell everyone knows if you want to create havoc and destroy and AT that you much get up to 88MPH and throw the shifter into reverse.
theLemur
Dec 27, 2014 01:01 PM
PoorDad
Nov 7, 2010 10:19 AM
integracura
May 29, 2006 04:32 PM
