Rough start after stall
Old May 10, 2013 | 01:10 PM
jonyi27's Avatar
Default Rough start after stall
So I stalled very lightly, I rarely stall, but when I try to turn it back on it turns on but rough then idles at 500 below and wants to die, I try and give it gas but there's no response... I give it a couple seconds then rpms go up and then it has gas response then I go.... This was very frustrating while in traffic.... This only happens when I stall... Any ideas what it can be... Thanks
Old May 10, 2013 | 01:16 PM
B_Swapped93's Avatar
Default Re: Rough start after stall
when was the last time you did a full tune up ?(plugs cap rotor etc).
Old May 10, 2013 | 01:21 PM
jonyi27's Avatar
I did my plugs not even a week ago, proper gap and torque spec, haven't changed the rotor or cap and wires yet, I'll be checking the cap and rotor next
Old May 10, 2013 | 01:29 PM
do that a bad cap/rotor can cause issues similar to yours. is you ign/mech timing on ?
Old May 10, 2013 | 01:44 PM
jonyi27's Avatar
Someone did say that my timing was off by a tooth but it is still good idle and all that does misfire sometimes
Old May 10, 2013 | 02:18 PM
set mechanical timing....don't go driving around if you're off by a tooth
everythingwentblack
Mar 26, 2009 11:21 PM
cooljerk187
Feb 26, 2004 01:48 PM
Bspec18
Aug 1, 2003 09:56 PM
sivik2nr
Jun 3, 2003 09:51 AM
